ADC_Chanels_in_HAL
  • November 1, 2023
  • 1445 views
Hi to all!  I connected all channels to possible pins in my ADC.  How I can use the HAL functions to select a separate channel and read the value from it?  Has anyone faced these issues?  I will be grateful for the answer!
Best answer by FBL
Hello @Embedded_dev1 ,
Here is an example firmware. You can simply configure ADC channel.
STM32Cube\Repository\STM32Cube_FW_F1_V1.8.5\Projects\STM32F103RB-Nucleo\Examples\ADC\ADC_AnalogWatchdog
This wiki might be helpful as well. Getting started with ADC - stm32mcu
FBLBest answer
To give better visibility on the answered topics, please click on "Best answer" on the reply which solved your issue or answered your question.Best regards,FBL
Thanks for the answer!
