STM32 MCUs Products
STM32F1x periodic external pulse counter
Posted on October 17, 2012 at 01:49Hi All,I’m using an STM32F103x.  I need to count the number of external pulses from a hardware detector, and take a snap shot of the pulse count at a precise frequency of 100,000 kHz.My current setup uses TIM5 CH...
cameron by Associate II
  • 1673 Views
  • 5 replies
DMA between external SRAM and LCD on FSMC
Posted on October 16, 2012 at 22:58 hello, i am trying to learn how to use DMA for frame buffer. Idea is to manualy fill SRAM with data (10k points each 16b) and send to LCD by using DMA. FSMC_Bank1_NORSRAM2 and adress: #define B...
linas2 by Associate II
  • 3093 Views
  • 7 replies
Example converting problem
Posted on October 17, 2012 at 17:36Hello, I am new to ST microcontrollers, just maybe 2 weeks ago I accidentally found about this crazy chip (STM32F4) and now i am already playing with it. I am interested in the I2S hardware and audio processing, so...
M0NKA by Senior
  • 1267 Views
  • 3 replies
stm32f407vgt6
Posted on October 13, 2012 at 16:43hi,  i have stm32 discovery board(stm32f407vgt6) and a new stm32f407vgt6 ic.i want to program the new stm32f407vgt6 ic.so i change the hardware settings in my discovery board.In discovery board contains STM32F103C8...
vinothraj by Associate II
  • 7959 Views
  • 18 replies
STM32F103RC SDIO
Posted on October 16, 2012 at 12:03Hi,I am using a STM32F103RC and successfully can access a 16GB SD card via SDIO.Every single try on a 32GB SD card fails.Is there some limitation? because any code I found (SDIO) works ok with <16GB and fails with ...
usb CDC control interface (can this be removed)
Posted on September 30, 2012 at 20:37I have the CDC example running great :)It pops up as 2 separate usb interfaces on my pc (0 and 1)I have noticed to send and receive data over the usb i only need the second interface. the first *control* interfac...
russdx by Associate II
  • 6326 Views
  • 22 replies
