STM32 MCUs Products
stm32f4 Discovery multiple potentiometers
Posted on November 11, 2012 at 09:33 Hi everyone, I'm trying to get a accurate reading out of 2 potentiometers but they keep affecting each other. Also when I press my touchpanel (XPT2046) the readout is affected.... Does anyone hav...
kenny__84 by Associate II
  • 2151 Views
  • 7 replies
Keil, initial clock configuration.
Posted on November 10, 2012 at 21:01I'm writing my own USART code to work with USART1. I need to know what the start-up code that keil gives you sets the clock initially at. I can change it manually but id like to know where the code is. Also USART1...
STM32F051 analog comparator?
Posted on November 09, 2012 at 15:59What is theinputresistance of theanalogcomparator in STM32F051?I can notfindthis informationin the Datasheet.
asrock70 by Associate II
  • 1207 Views
canopen
Posted on November 07, 2012 at 08:01hello every one.i want to use stm32f107xx as canopen device (Higher Layer Protocol based on standard CAN drivers) . is there any library or any thing to help me? #can #hlp #canopen #can
Clive thanks!
Posted on November 09, 2012 at 18:39Clive1 thanks for your response! :) could u please explain how it works? im learning shift operators and addressing registers as struct. it`l be helpful if u could guide me thanks! :)
ADSTART bit
Posted on November 08, 2012 at 11:54Hi everybody. I have similar problem, I already wrote here. In the past I wrote here, that when I tried to lock set pins on GPIOA channel, but System Viewer Windows showed mi that LCKR register of given pins of GP...
Header Pins that are free on stm32f407vgt6 board.
Posted on November 08, 2012 at 19:00My hardware guy tells me that most of the SOC peripherals don't make it out to the header pins on this board. He says they are tied up with board supported peripherals. 1) In general is this true? Is this board de...
How to write set of bits in ODR?
Posted on November 08, 2012 at 16:15hello , im a newbie to stm32 and im just starting with stm32f4 discovery, i have to write an 8 bit value to GPIOA ODR from bit2 to bit9 while not altering bit0 and bit1 how can i do that? it`s a noob question but ...
