STM32 MCUs Products
STM32F1 Clock/Calendar BUG
Posted on April 24, 2014 at 15:08Hello, I noticed a problem in the software implementation of STM32F1 's clock/calendar. If the device is switched off for a long time (>= 255 days) it will enter infinite loop inside  CheckForDaysElapsed() (which is ...
tetj by Associate II
  • 2041 Views
  • 4 replies
Registers issues (volatile, bit-access and bit-field)
Posted on April 28, 2014 at 00:04Hi everyone, I'm trying to understand how registers and memory really works in a microcontroller and how to access data in registers using C Now I can access any address in the memory and I can write any data to it...
Cube for STM32F2
Posted on March 04, 2014 at 15:31Is there a planned release date for the Cube for the STM32 F2 series?
Multiplexing SRAM,NOR Flash and NAND Flash ?
Posted on April 26, 2014 at 01:36Guys, How can I multiplex SRAM,NOR Flash and NAND Flash on PD7 ? It's function as PD7 FSMC_NE1/FSMC_NCE2 on pin 88 for STM32F103VCT6, is it configurable via software or I need to put a latch / multiplex chip for it ?...
STM32 truncated documentation
Posted on April 28, 2014 at 08:19Hello there,I was looking for the STM32F103RB datasheet but all i found is some 105 pages truncated document with only overview of the device. I was looking for something more like 1005 pages. I looked deeper into th...
STM32f407 external pulse counter channel selection
Posted on August 21, 2013 at 12:06 Hi guys, I am having a big problem; I would like to count external pulses with 2 timers; TIM 2 and TIM5. The problem is, that I need to connect my two timers to the 2 I/O pins that are free. So th...
anze by Associate
  • 5185 Views
  • 12 replies
TIM_OCMode_Toggle PWM Duty Controll
Posted on October 05, 2013 at 08:36I'm an absolutely beginner in microcontrollers. I want to create a PWM signal wave signal  to drive main power switch at 100Khz TIM1CH1&TIM1CH1N of   STM32F103VC. I change duty (CCR1_Val) but the duty stay same at...
stm3223 by Associate II
  • 7751 Views
  • 15 replies
