STM32 MCUs Products
STM32F3 I2C Restart Condition
Posted on July 08, 2014 at 11:33 Hi i have e following code for communication with an I2C Device. #define DEVICE_ADDR 0x14 #define DEVICE_READ 0x4c Therm_Timeout = 10 * Therm_LONG_TIMEOUT; while(I2C_GetFlagStatus(DEVICE_I2C, I2C...
DMA overwrites rest of memory [solved]
Posted on July 06, 2014 at 16:46Hello,I am working on STM32L151ZC. I use DMA to continuously read 28 ADC channelsIt seems that the DMA is periodicaly (les often than the ''normal operation period'') overwriting memory that it shouldn't access direct...
atsju2 by Associate II
  • 2984 Views
  • 5 replies
USB communication between MCU and PC
Posted on July 07, 2014 at 17:19HeyI need some help for my project (I'm using STM32f4 discover board). I would like to exchange data from mcu to pc and pc to mcu. Data will be an array with some informations. I tried USB CDC (works fine) but the thr...
configuring watchdog for freertos
Posted on July 07, 2014 at 14:52how to configure watchdog timer for the freertos in stm32l152cb MCU, the freertos has 3 tasks running. when to update the WWDG counter, in the st example wwdg counter is updated in a while loop every 50ms . but how to...
Bootloader using USART 2 on STM32L152VB
Posted on July 03, 2014 at 17:56I am attempting to communicate to the bootloader through RS232 on USART 2 on the STM32L152VB.  I have Boot 0 pulled up and I believe I am in the bootloader because the application code is clearly not running.  I am us...
rgrindall by Associate II
  • 2425 Views
  • 5 replies
STM32F407 PWM issues
Posted on July 04, 2014 at 17:29 Hi all, I'm trying to use a PWM on a Olimex STM32-H407 board to drive the green LED (only user LED on the board), but without any success. I managed to use timers for generating output signal to turn on/of...
marko2 by Associate II
  • 1373 Views
synchronous mode of usart
Posted on June 28, 2014 at 11:52hello I want to use synchronous mode Usart. but i dont know how to set clock pin to for example 10 MHZ. please help me. thanks #stm32 #synchronous #usart
Issue with USB library on discovery f4 board
Posted on July 06, 2014 at 00:11 Hi guys, i`ve spent several hours trying to figure whats wrong in my initialization routine, but no luck at all... Here is my code #include ''system_stm32f4xx.c'' #include ''stm32f4xx.h'' #include ''us...
Bogdan by Senior
  • 1312 Views
  • 3 replies
