STM32 MCUs Products
shield
Posted on December 05, 2014 at 18:25Does ST Nucleo Board support competitors Shield from Arduino? Or any plan?
Bootloader
Posted on December 05, 2014 at 18:22Does ST provide a bootloader to just have USB interface for programming software without a programming tool?
STM32L Discovery Board - Touch panel
Posted on December 05, 2014 at 17:35Anyone knows a code to use the touch sense panel of the STM32L Discovery board.I mean a simple program that puts in a variable the touch position.Thanks
what is the meaning of ''on-the-fly''?
Posted on December 05, 2014 at 12:52Hi everybody..I wanna ask to what is the meaning of ''on the fly''? I interesting with pwm generator for motor controller. And I want to change speed of motor whenever I want. Speed is related with pwm frequency a...
STM32F4 - FFT : Why global variables
Posted on October 16, 2014 at 17:02Hi,I'm using CMSIS DSP Libraries with a microcontroller STM32F4 to compute FFT. Here is my function code to compute the FFT:void fftProcess(float32_t *parSignalInput_f32, float32_t *parfftOutput_f32){    uint16_t i...
Setting up a new LCD with STM32F429
Posted on December 02, 2014 at 17:49Hi, I have this LCD module I want to get running with the STemWin library. http://www.vpistrategicsourcing.com/datasheets/T043ZT268A_Datasheet.pdf I found that STemWin has display drivers for some chips but the di...
ydamihux by Associate
  • 5118 Views
Pin versus port in STM32Cube example
Posted on December 04, 2014 at 01:32 I changed the pins in the UART_TwoBoards_ComPolling example for the Nucleo STM32L152RE board. It did not work until i also changed the port. Is there a fixed connection between pin and port? How d...
Stm32f407 Can bus problem
Posted on November 04, 2014 at 16:40 Hi all, I am working on a project with stm32f407 and i want to communicate to stm32f407 boards with each other using can communication. I am using sn65hvd transceiver and i made this scheme : ...
