STM32 MCUs Products
STM34f429i Discovery i2s/i2c question
Posted on August 13, 2015 at 08:52Hello everyone.I am building a simple car audio/video player, and the 429i with the LCD built into it seems perfect. I want to use a different DAC, specifically Ti's PCM5122, so that I can use higher grade amps, amo...
Communication STM32F3 to STM32F4
Posted on August 13, 2015 at 09:42Hi Friends,I'm working in a company temporarily. They gave me two boards. STM32F303VC and STM32F429ZI. I have one project to do. This project is about to communication between two boards. It's simple but i'm new in ...
SDRAM and unaligned memcpy causes exception
Posted on August 13, 2015 at 00:29I am using the The STM32F7 discovery kit (32F746GDISCOVERY) kit and I have run into an issue with memcpy using IAR (which seems to do some clever internal aligning and then copying 4 byte words).In short, the copy f...
wilfred by Associate
  • 1761 Views
  • 1 replies
Stm32 Nucleo L152RE and low power configuration
Posted on July 30, 2015 at 16:36Hi to all, i use stm CubeMX with HAL library and Keil now i want develop  the low power configuration on my Nucleo  stm32L152RE, can you see a example or other information? can you help me? best regards A.
antonio23 by Associate II
  • 1087 Views
  • 1 replies
IBIS Model understanding
Posted on August 13, 2015 at 12:48Hello everyone!I am currently working on a PCB on Altium Designer 15 and I am trying to do some tests on signal integrity but the proper driver on I/Os must be chosen.I already have the IBIS model ''stm32f427_437_42...
How frequency and powerconsumption are related
Posted on August 13, 2015 at 04:54What I'm about to ask is somethig generic and basic So everywhere it can be found that for going to low power mode reduce the clock frequency, How reducing clock frequency reduces power consumption ? #low-power #...
CubeMX ADC sampling time
Posted on August 12, 2015 at 19:30I use CubeMX to generate code.How can ADC Sampling Time?CubeMX does not give option for that and always generate:SamplingTime = ADC_SAMPLETIME_3CYCLES;My problem is if I changed it manually (to for example 28 cycles...
smhhadima by Associate II
  • 1278 Views
  • 3 replies
IAP Ethernet(web server) issue on STM32cubef4
Posted on August 13, 2015 at 08:18Hi all,I am testing on IAP Ethernet(web server) functionality but I can't download my application.Here is my test environment- STM32f429 Eval board- STM32cube4 1.7.0- Eclipse + GCC, IARAnd here is my story,I program...
mclapd by Associate II
  • 781 Views
  • 1 replies
