STM32 MCUs Products
PCB Document in Design/Schematic Packs; Downloads
Posted on August 11, 2016 at 17:37Hi, I'd like to designe a PCB with a STM32F7xx. You use to have in the Design/Schematic Packs also the xxx.PCBDOC. E.g. STM3210C-EVAL (MB784C, MB785A) They  save lot of work and time. But I miss the PCB Document for...
christos by Associate II
  • 4702 Views
  • 6 replies
basic bootloader for M0
Posted on June 20, 2016 at 23:21Hello Forum, I've been reading on the forums about custom bootloaders stored in flash and I was wondering if there was another possibility (possibly because I want to avoid messing with stack pointers, reset vectors e...
stenasc by Senior
  • 11300 Views
  • 43 replies
STM32 external sdram strange problem
Posted on August 12, 2016 at 07:27STM32 external SDRAM(32bit width,FSMC interface) 16bit and 32bit writing OK,but 8bit writing is not OK, shown below,source file is also attached. Test Results uint8_t  write_buf1[100];write_buf1[0] = 0x01;  //0xC000...
lbguan by Associate
  • 1607 Views
fp issue: vstm/vldm all 32 fp registers at once
Posted on August 12, 2016 at 01:09 A few details: both code and data caches are enabled. 216MHz SysClk. Timer ISR schedules a task every millisecond. SCB.SHCSR=1<<18 to enable use of usage fault ISR for the fp trap handler. All ISR’s mentioned a...
picguy2 by Associate II
  • 1340 Views
STM32F103 USART2 CAN'T SEND DATA
Posted on August 08, 2016 at 08:42Hi all,I've built USART2 connection with using none-flow-control via rs485 through my pc. Sending data from my pc to stm32f103 is working correctly however, i can't send any data from stm32 to my pc.Do you have any ...
STM32F103RET High speed communication with SDcard!!!
Posted on August 12, 2016 at 14:26Hi I want to know if I can reach a writting speed of 3-4Mbytes/sec to MicroSD ?Microcontroller is STM32F103RET.Clock rate: 72MHz.MicroSD 2-4G calss 10.SDIO protocol.If you have any same experience , please to help m...
eleman3 by Associate
  • 835 Views
  • 1 replies
