STM32 MCUs Products
Resolved! Disabling flash sectors protection through dfu
Posted on May 18, 2017 at 11:33Hi,Is there a way to disable the ''Flash sectors protection'' through USB (DfuSeDemo/dfu-util/...)?It can be done using the STM32 ST-LINK Utility,by going to Target > Option Bytes, and unselecting all the sectors under...
MDW by Associate II
  • 1364 Views
  • 1 replies
Will CMSIS drivers be available for STM32L4 and if so when?
Posted on April 07, 2017 at 13:22Will ST provided CMSIS drivers for STM32L4 in the stm32cube_ ...  and if so when please?I am particularly interested in the SD card and USB.I plan to use the Keil RTX5 CMSIS RTOS2 which demands CMSIS drivers.ST any p...
John F. by Senior
  • 2082 Views
  • 8 replies
Difference between HAL_HRTIM_RegistersUpdateCallback, HAL_HRTIM_CounterResetCallback and HAL_HRTIM_IRQHandler
Posted on June 09, 2017 at 05:23Thank you for your patronage. I want to use Interrupt Service Routine(ISR) as shown in the picture below. So I want to use HAL_HRTIM_RegistersUpdateCallback or HAL_HRTIM_CounterResetCallback or HAL_HRTIM_IRQHandler. W...
0690X00000607GHQAY.png 0690X00000607ILQAY.png 0690X00000607IBQAY.png 0690X00000607IVQAY.png
Ken Inoue by Associate III
  • 785 Views
  • 0 replies
I2C code error and port damaged
Posted on June 09, 2017 at 03:59 I am using STM32Fxx library. I am not using STMCubemx. Issue I am facing is that the first time I run I2C communication after turning on MCU, the busy flag timeout occurs. while(I2C_GetFlagStatus(I2C1, I2C_FLAG...
FLast.5 by Associate II
  • 892 Views
  • 0 replies
How to use HAL_HRTIM_CounterResetCallback
Posted on June 09, 2017 at 03:28Thank you for your patronage. I'm Japanese. I want to use Interrupt Service Routine(ISR) as shown in the picture below. So I want to use HAL_HRTIM_CounterResetCallback.I wrote the program as shown below, but HAL_HRTIM...
0690X00000607HXQAY.png 0690X00000607IGQAY.png 0690X00000607I1QAI.png 0690X00000607HwQAI.png
  • 879 Views
  • 0 replies
STM32F401RE Nucleo + SDIO + FatFS + CubeMX 4.21.0
Posted on May 30, 2017 at 23:52STM32F401RE Nucleo + SDIO + FatFS + CubeMX 4.21.0, anyone can confirm me that SD is working and CubeMx dont'create fault code? I'm trying to write a file in SD card but at f_printf(....) CPU still locked (hard fault?)
