STM32 MCUs Products
Bug Report cubeMX 4.23 IAR code genereator
Posted on November 28, 2017 at 09:02HelloI use cubeMX 4.23 and have seen that the code generator for IAR itroduces absolute paths in the *.ewp project file in the include section and for all used library source files which are used in the project.I ...
F103 SDIO Init Problem
Posted on March 30, 2018 at 05:34The problem is when code run to HAL_SD_ConfigWideBusOperation(&hsd, SDIO_BUS_WIDE_4B), it always return HAL_ERROR.And then SD init failed and stuck in _Error_Handler function.MCU: STM32F103VETxCube MX Version: 4.25.0...
Zhi Pang by Associate III
  • 5126 Views
  • 7 replies
Resolved! Working of DAC in STM32F103RB
Posted on May 08, 2018 at 19:46Firstly, what is the purpose of DHR (Data Holding Register) and DOR (Data Output Register)?Secondly, where does the data go after DOR register?Thanks!!!#dac #stm32f103rb #analog
FCU001V1
Posted on December 11, 2017 at 18:55I bought the fcu001v1, the device just started to blink of led LD2 and LD1 off, i tried searching for bluetooth connectivity. device was not listed.i tried to connect the SWD of FCU001V1 through my STlink V2 on ST...
Suddenlink tech support
Posted on May 10, 2018 at 13:39If ever you confront any kind of technical error in the Suddenlink Email such as sign in problem, forgotten password, or any other then you are required some help to rectify them. Well, you should not worry as through ...
Resolved! STM32F207 customer HID do not work
Posted on May 08, 2018 at 07:31Hi,I'm testing the demo on your website designed by itself.STM32Cube_FW_F2_V1.7.0\Projects\STM322xG_EVAL\Applications\USB_Device\CustomHID_Standalone,After the target code is downloaded to the board, the device manager...
duan jze by Associate II
  • 3522 Views
  • 7 replies
