STM32 MCUs Products
Resolver for STM32F4
Hello everyone. I'm working on a project. I must use a resolver for our servo motor. But I could not find any sample code for resolver.Can anyone help me?Thank you.
Mert by Associate
  • 3838 Views
  • 7 replies
Voltage problem on VDD pin on SWD connector.
It's my first design with a STM32 MCU. I want to program a MCU on my custom board with the ST-LINK but when I try with STM32 ST-LINK Utility the connection doesn't work. The STM isn't recognized. When I measure VCC signal on the connector SWD I have ...
Resolved! STM32F439NIH can't get PLLCLK on MCO1 (solved)
Posted on February 17, 2017 at 12:29I want to have 60 MHz on the MCO1 pin PA8. I use an external 25 Mhz crystal. The PLL delivers 180 Mhz to the system clock. I've used STCubeMX to configure the clocks to get 180 MHz / 3 on MCO1.Unfortunatly I'm not...
lasse by Associate II
  • 1355 Views
SPC570S50E1 UART Confinguration
Posted on March 29, 2018 at 10:06Hello Everyone!I am trying to configure LIN_FLEX_0 channel for UART communication. Following is my code for the configuration.&sharpdefine LIN_CH0 LINFLEXD_0LIN_CH0.LINCR1.B.INIT=1;         /* Put LIN into INIT mode ...
Thank you
Thank you in advance for your helpBest regards
Jessy J by Associate II
  • 2230 Views
  • 4 replies
