STM32 MCUs Products
Serial UART design for various size transfers
Hello, I'm writing an application on the STM32F303 Nucleo board that uses the serial UART to receive commands and send responses. I believe example code from the standard peripherals library shows either single byte transfers or fixed size buffer t...
Resolved! How to use RTC periodic wakeup (from standby) on STM32L0
I am trying to periodically wakeup STM32L010K8 from standby mode. The project is generated is using CubeMX. The device doesn't wakeup unless I reinitialize RTC everytime it resumes from standby. How can I avoid reinitialization of RTC everytime?/* US...
Raghu by Associate
  • 2593 Views
HAL_SPI master OVR error
Hi everyone,I'm using the STM HAL for my SPIcommunication in master mode. Toreadout my ADC, I implemented a state machine, which startsthe ADC conversion and then once a data ready signal is received, the data isclock out in SPI full duplex mode. Onc...
DZimm.9 by Associate III
  • 1144 Views
  • 0 replies
Executable format for flashing under Linux
Hi,I use Linux as a development environment for STM32F429. I've created several Makefile files for my project and I'm able to compile it. Now I'd like to flash project's output binary file to STM32F429. I know that it is possible to mount STM32F429 ...
WKowo by Associate II
  • 2576 Views
  • 3 replies
