STM32 MCUs Products
Resources for SPI connection to external flash memory
Hi,I would like to know if there are any resources for learning and understanding how to communicate (read/write/erase) from an external flash memory using SPI.I am using an STM32F446RE and my external flash memory is a w25q128.Ideally I would like t...
DCont.1 by Associate II
  • 4136 Views
Resolved! STM32 CAN2 normal mode not working
Hello,I have problem in CAN2 STM32F4, that in mode Loopback working good, but when i change it to mode Normal not working (not transmission )Please do you have a solution for working in the mode Normal ?
MBRAH.1 by Associate
  • 1199 Views
  • 1 replies
STM32H7 - Sending CMD5 to eMMC card
Hi,I'm working with an STM32H7 connected though SDMM1 (1bit bus width) with an eMMC, I need to put the eMMC into sleep mode so we can reduce the power consumption when it is not being used.According to the information I've been able to find we need t...
CDiaz.2 by Associate II
  • 1682 Views
  • 1 replies
Signal Integrity Simulation with IBIS model of STM32H7B3IIK6
Hello.I have got the IBIS model of STM32H7B3IIK6 from ST website, but there is no document to explain how to use this IBIS model. As there is so many sub-models included, I don't know what model I should selected for the FMC data pin, e.g. io8_ft_fs_...
WLiao.1 by Associate II
  • 1323 Views
  • 1 replies
Raw RNG samples STM32F7: has anyone already tried it?
Hi,I am actually trying to collect raw samples from TRGN module of a STM32F7.To be more clear, raw sample means unprocessed data coming directly from the source. It is possible using a special IO configuration setup and external equipment in order to...
MLave.2 by Associate II
  • 1934 Views
  • 4 replies
I2C flag RXNE automatically clear before read register
I initiate reception from the microcircuit for stm32h723. However, the code hangs while waiting for the RXNE flag. In the debug, step by step, you can see that the flag is set after START, but is immediately reset to zero in the next step, before che...
NBoga by Associate
  • 1113 Views
  • 1 replies
