STM32CubeMX (MCUs)
Ask questions on STM32CubeMX. Discuss code generation and configuration challenges, among other topics.
STM32CubeMX 6.17.0 released
We are pleased to announce that version 6.17.0 of STM32CubeMX is available. What is new in 6.17.0: Added support for new microcontrollers across the STM32WBA, STM32H5, and STM32U3 seriesAdded support for new boards: NUCLEO-WBA25CE1, NUCLEO-H5E5ZJ, ST...
Aimen1 by ST Employee
  • 1591 Views
  • 0 replies
  • 2 kudos
Resolved! bug in stm32CubeMX for SDIO 4bit
stm32cubeMX have bug in SDIO 4biti use stm32f407vg, stm32CubeMX ver 5.4.0in use 1 bit true work but 4bit not working.this code generate for SDIO mode: SD 1 bit/** * @brief SDIO Initialization Function * @param None * @retval None */ static vo...
kshin.111 by Associate III
  • 2951 Views
  • 6 replies
Add custom file to project
Hi,Please help me, how to add a custom file into my project. When regenerate source by CubeMX it will delete my sourceThanks,
DLy.1 by Associate
  • 1540 Views
STM32F746ZET6 || Technical Query
Hi Team,Greetings of the day.We are using the STM32F746ZET6 controller from STM.We are using all the timers for our development.While configuring that timer we faced some conflict errors on that. Kindly help us on this to solve the issue.1. We are co...
MKUMA.13 by Associate
  • 947 Views
  • 1 replies
May be a bug in STM32F3xx_HAL_Driver?
I'm creating serial communication application.I'm using STM32F303RE and USB CDC interface generated by STM32CubeMX.I used USBD_CDC_TransmitPacket() for transmitting data from device to PC.But when the data size == 64*x then read() in PC program didn'...
SAoya.1 by Associate
  • 997 Views
I installed STM32CubeMX 5.6.1. When I ran CubeMX it freezes when I click Install/Remove embedded software packages. How can I fix that?
EDIT:I installed STM32CubeMX 5.6.1. When I ran CubeMX it freezes when I click Install/Remove embedded software packages. How can I fix that? There is a section for managing software installation. When I click any button here ("CHECK FOR UPDATES" or "...
