STM32CubeMX (MCUs)
Ask questions on STM32CubeMX. Discuss code generation and configuration challenges, among other topics.
STM32CubeMX 6.17.0 released
We are pleased to announce that version 6.17.0 of STM32CubeMX is available. What is new in 6.17.0: Added support for new microcontrollers across the STM32WBA, STM32H5, and STM32U3 seriesAdded support for new boards: NUCLEO-WBA25CE1, NUCLEO-H5E5ZJ, ST...
Aimen1 by ST Employee
  • 1734 Views
  • 0 replies
  • 2 kudos
  • 1734 Views
  • 0 replies
  • 2 kudos
Resolved! STM32CubeMX on MacOS buggy - does not show (sub)-folders
HiI recently started using STM32CubeMX on MacOS and noticed that navigating through the (sub)-folder is kind of buggy or I am doing something utterly wrong.I want to create a project inside my documents folder. But everything that is inside my docume...
AAnth.1 by Senior
  • 287 Views
  • 1 replies
  • 2 kudos
Resolved! SMPS Pinout not available (STM32WBA)
Hello!I'm trying to set up a program via STM32CubeMX. The MCU I'm trying to use is the STM32WBA65CIU6 with the SMPS Pinout.source: datasheet page 72 (https://www.st.com/resource/en/datasheet/stm32wba62ci.pdf).However this configuration seemingly isn'...
le1 by Associate
  • 653 Views
  • 4 replies
  • 6 kudos
Resolved! Cubemx & Stm32U031
Inside Cube config, i do not get the other internal connected pins on pin 14, only PA8... in older versions it was available. The chip is STM32U031F8... What do i do wrong.. i need to use the uart_tx function on pin 14... Thank you  Old version from ...
KJeps.3 by Associate III
  • 509 Views
  • 5 replies
  • 1 kudos
Announcement
We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
