STM32 MCUs Products
Calling RTC_Init
Posted on June 27, 2011 at 12:13Good morning everybody! I'm evaluating ST standard device Library with STM32L discovery board. I want to test RTC and so in my main I want to call RTC_Init and so on. So I prepare a RTC_InitType  structure, I create a...
Interupt priorities
Posted on June 28, 2011 at 09:38Hi All, Can anyone explain the difference between the prem and sub interupt priorities.  For example what TIMER_1_IRQ_PREM_PRI and TIMER_1_IRQ_SUB_PRI. -- Thanks #stm32-c-embedded
RTC calendar on STM32F100x
Posted on June 29, 2011 at 13:02Hi, i've to implement a RTC calendar on my STM32F100 microcontroller. I've the RTC library, but i'm searching a so called ''calendar.h'' that already has defined: days, weeks, months,years etc.. Some ideas?? #time...
Any good (In depth) STM32 I/O tutorials?
Posted on June 26, 2011 at 19:08I've built a gas turbine engine, which currently runs on a variety of manual valves/switches to run. What i want to do is to install solenoids into my fuel rings/pump supply, and relays on the switches controlling my ...
Hard Fault Error - STM32F100C8
Posted on June 27, 2011 at 12:34I am trying to implement EEPROM emulation in the flash memory. I am able to write and read the data from flash. When trying to write the second data it is going to HARDFAULT Error. I m not sure why this happens. Belo...
ezyreach by Associate II
  • 4604 Views
  • 11 replies
SPI & DMA - DMA irq not called out 2
Posted on June 01, 2011 at 14:45Hello, I encountered problems when trying to send SPI data by means of DMA. It seems that DMA transfer never starts. The sequence of configurations commands is as follow: 1) Enable SPI and DMA clocks     RCC_AHBPeri...
snafu by Associate II
  • 1078 Views
  • 1 replies
