STM32 MCUs Products
IWDG on STM32f3
Posted on July 10, 2013 at 10:34Dear all, I'm currently developping under stm32f3 discovery and I'm experiencing difficulties with the IWDG. In a first version of my software, I've been using the std peripheral library to set up the IWDG with the fo...
debugging in Eclipse
Posted on July 08, 2013 at 08:11Hello everyone, I am a new to working wtih ARM processors.I've a STM32F4 Discovery board.I tried to setupSTM32F4 development environment on Ubuntu as stated in this site http://shareee.netne.net/wordpress/?p=83. But W...
PWM
Posted on July 05, 2013 at 12:20Hi,I'm very demoralized to study PWM for stm3220G evaluation board. I need a tutorial/example to understand concepts. For example: why does gpio_moder configure in AF (alternate function)? I configured GPIOA1   in my ...
mosine by Associate II
  • 2667 Views
  • 12 replies
Timer triggers the ADC to work
Posted on June 30, 2013 at 17:27I'm using TIM1 to generate a PWM signal of period 1 sec and a varying pulse duty.This pulse undergoes some signal conditioning and then entered to the ADC, worth to mention that nothing happens to the signal's period ...
sherif by Associate II
  • 6341 Views
  • 17 replies
stm32f373 single ended zero reference mode SDADC
Posted on July 08, 2013 at 12:54Hi. Just to be sure (because the manual is not very clear in this case..): When the manual states that in single ended zero reference mode the offset is dependend on gain variations it practically means that i can ac-...
markus2 by Associate
  • 1368 Views
  • 1 replies
STM32F107RCT6 USB DFU Bootloader not Working
Posted on July 08, 2013 at 16:34Hi, we want to use the STM32F106RCT6 in our Future Products. So we Build an prototype an all works fine except the USB DFU Bootloader. We plugged the USB Cable in and the PC didnt recognize the Device. The Markings on...
s2 by Associate
  • 2285 Views
  • 5 replies
STM32F3 Discovery - ADC EOC Interrupt
Posted on July 09, 2013 at 16:58I'm working on getting my ADC to be interrupt driven.  From my code below, I can verify that the interrupt is set in the IER (interrupt enable register)  for ADC1, and that the EOC bit is high.  For some reason, thoug...
mattfox by Associate II
  • 1092 Views
Using User Button on stm32f3 discovery
Posted on July 08, 2013 at 17:21Hello I'm new to stm32 and I'm now working on the stm32f3 discovery board with a 7-segment display.I want to use the User Button to make the digit on the display increment whenever the button is pressed. But I couldn'...
mehdi23 by Associate
  • 2087 Views
