STM32 MCUs Products
STM32f415RG hits reset_handler (Mikroe MINI M4)
Posted on May 06, 2015 at 02:38hi everyone..I bought a MINI M4 from mikroelektronica and I decide to use KEIL 5.04 for the firmware, I ported a proyect from STM32F4DISCOVERY and it seems that it worked, i try the blinking led, push button to turn on...
dracog71 by Associate II
  • 704 Views
  • 0 replies
Bootloader Jump failing going to Usage Handler Fault
Posted on May 05, 2015 at 14:48Dear All, I am writing STM32F105 based bootloader. I am able to write the Application File contents to the Flash Application Area. But the Jump to Application is failing; I am getting following Errors: 1. Usage Fault...
STM32f10x Usart polling problem
Posted on May 04, 2015 at 15:53 Hi, I have a problem with usart2 with my stm32f10x. I want to send data using polling and the TXE Flag does not SET and i don't know why. This is the init of the GPIO Ports. /** USART2 GPIO...
lattner by Associate II
  • 10632 Views
  • 7 replies
ADC help configuring interrupt and triggering STM32f4
Posted on May 04, 2015 at 12:58 Hello, I want to calculate distances using ultrasounds. I configured correctly an ultrasound transmitter to make pulses of 40kHz. Now I'm trying to configure STM32f4 to read data from the ultrasound receiver. ...
fiulala by Associate II
  • 947 Views
  • 1 replies
unable to debug using gdb and openocd
Posted on May 01, 2015 at 11:23Hello,I�m quit new to STs micro controllers and openocd. I want to use the STM32L152RE on a Nucleo board. I�ve installed the head version of openocd to get support for this board. I start openocd with following paramet...
torsten2 by Associate II
  • 1077 Views
  • 1 replies
STM32 Nucleo memory mapping
Posted on May 04, 2015 at 22:59Hi, I'm trying to understand the memory mapping used on the STM32 Nucleo series of boards. Specifically, I'm trying to understand how I can use SRAM vs Flash for program execution.  In short, i am trying to get my pr...
karthik2 by Associate II
  • 3702 Views
  • 3 replies
Open407I-C - Touch
Posted on May 04, 2015 at 21:28I'm not able to work with the touchpanel kit. I took the program that came as an example, I made some adjustments in order to run in coocox, but the touch of the x and y position always returns zero.Does anyone have th...
ricardo by Associate II
  • 1168 Views
  • 1 replies
