STM32 MCUs Products
How to reset timer counter value once captured
Posted on November 25, 2015 at 17:32 I have a timer set up with a capture register which loads the counter value on a rising edge with the code below. However the counter value keeps increasing until overflow (not when counter value loaded into ...
jackygip by Associate II
  • 2737 Views
  • 1 replies
UART framing error on STM32F0 device
Posted on March 19, 2015 at 12:18Hello! I am currently using STM32F030R8T8 for communication purpose (RS485). The functions I wrote to communicate seems to be working fine but most of the time the communication stops and refuses to restart. I implem...
memory calculation
Posted on November 25, 2015 at 14:32Hi,anyone describe whats the below lines means.'' memory device containing 64Mbit Pseudo Static Random AccessMemory using a self-refresh DRAM array organized as 4M words by 16 bits.''
arunease by Associate II
  • 861 Views
  • 1 replies
SysTick and DMA interrupt priorities
Posted on November 20, 2015 at 08:46Hello,  I noticed that in the code generated by CubeMX SysTick interrupt is assigned the highest priority (0). And DMA interrupts (I didn't yet use any others) get assigned the same priority too. However, DMA ISR ...
rgesikov by Associate II
  • 1879 Views
  • 3 replies
UART Tx DMA variable length
Posted on November 25, 2015 at 03:39 I am currently using STM32F4 Discovery board, and i configure UART 2 into DMA mode for sending data. i am able to send data with a fixed length to UART 2 using DMA. But, i want to send data with a var...
hosweetim by Associate II
  • 1036 Views
  • 1 replies
TIM6 interrupt in debug/breakpoint
Posted on November 20, 2015 at 14:22Hi everyone, I need some lights on the ability to switch off interrupt of TIM6 when stopping at a breakpoint. I did call the macro:     __HAL_FREEZE_TIM6_DBGMCU(); But nothing, I still jump into the TIM6_IRQHandle...
yannick23 by Associate II
  • 3074 Views
  • 8 replies
  • 1 kudos
FLASH PGPERR PGSERR
Posted on November 20, 2015 at 13:29Hello I need some help to understand my problem. I'm using eeprom emulation V3.1.0 MCD from Application Team and that works fine. When I reboot I get the PGPERR and PGSERR bits set after a while. I placed breakpoi...
STM32 HAL CDC example
Posted on November 25, 2015 at 13:25Hello there,I am trying to use usb device cdc protocol for my device. I have sucessfully generated code with CubeMX and the COM port is visible on my connected PC. The problem is, I cannot find any examples on how...
calculation
Posted on November 24, 2015 at 15:43Hi I could not able to understand a particular page in reference manual (FMC).. i have attched the page. Could anyone explain that.  how the memroy capacity is 512  mb. it showld be 2^26 is 64 mb ?
  • 1440 Views
