STM32 MCUs Products
SPWF01SA SSL Library
Posted on November 27, 2015 at 16:46Hi. I want to know which SSL library is integrated in SPWF01SA (it is WiFi module)? In the feature list is written that SSL/TLS 1.2 is supported but I need to know the specific library inside. Also, is it possible...
ta by Associate II
  • 893 Views
  • 1 replies
STM32F3 GPIO current sourcing question
Posted on November 30, 2015 at 10:52Hi, I am using STM32F301. If I configure the GPIO pin to be output mode, and configure it to be open-drain with pull up, what would be the pin's current sourcing capability? What is the value of the internal pull-...
song by Associate II
  • 955 Views
  • 1 replies
CIFS/SMB Library for embedded systems
Posted on October 21, 2015 at 16:45Hi! I'm wanting to connect my STM32 board to my network and be able to access files on my local network share. Does anyone know of a SMB/CIFS library for embedded systems that I could use? Cheers!
STM32F0 Timers
Posted on December 02, 2015 at 00:56I am having trouble creating a PWM output using a timer (timer 3, channel 1). Processor is an STM32F072CB. I'm using the following code: Note: GPIO clock is enabled for port A   RCC_TypeDef  *rccptr = RCC;   // En...
greenk by Associate
  • 1486 Views
STM32F7 Questions regarding code and performance
Posted on December 02, 2015 at 08:20 Hello. I have very DSP load program to run, and STM32F4 is not up to the task, so i switched to STM32F7 and HAL ( it is just asking for trouble ) I have few question related to code execution from...
I2C setup with Hal libraries
Posted on December 02, 2015 at 15:03 Hello everyone, I am new to this forum and to ST microcontrollers and need some help.. Trying to inialize and pick the right functions for Read and Write from the cube(HAL) libraries, to connect with an...
td by Associate II
  • 981 Views
  • 1 replies
STM32L4 ADC partially working
Posted on November 27, 2015 at 17:10Hello,I'm using IAR & cubeMX, and the nucleo board6 regular channels, no injection :1/ internal TS2/ A8 (connected to OPAMP 1) forced at 3.3V3/ A9 forced at 3.3V4/ A15 (connected to OPAMP 2) forced at 3.3/2 (volta...
tarzan2 by Senior
  • 1217 Views
  • 3 replies
