STM32 MCUs Products
F407VG's USB CDC And Getting Data To The PC
Posted on January 06, 2016 at 07:15 Getting a working CDC VCP on the STM32F4DISCOVERY is almost there. Device enumeration, SET/GET_LINE_CODING, SET_CONTROL_LINE_STATE and VCP PC -> STM32 data delivery are in place. Workalot is stuck on ge...
Workalot by Associate III
  • 1275 Views
  • 1 replies
STM32F4(407) DISCO CAN bus problem
Posted on January 12, 2016 at 07:30The original post was too long to process during our migration. Please click on the attachment to read the original post.
togsin by Associate III
  • 815 Views
  • 0 replies
Bidirectional pins/databus?
Posted on January 11, 2016 at 17:39My display has bidirectional or databus pins. It has also LCD_WR and LCD_RS pins to tell how it should work. Is there an IO port or pins which could directly drive those. I know it is possible to change direction o...
LMI2 by Lead
  • 1033 Views
  • 3 replies
How to generate PWM on TIM3 - CH3 on STM32F103 device
Posted on January 10, 2016 at 14:32 Hello all, i have some mouses around my house and need a pwm driver for a mouse trap but i have some dificulties generating a pwm signal on PB0 ( Timer 3 channel 3 output) RCC_APB2PeriphClockCmd...
Bogdan by Senior
  • 3579 Views
  • 5 replies
STM32f103 and measuring of LSI frequency
Posted on January 10, 2016 at 02:45Hello, I'm trying to use LSI for RTC, but can't calculate correct prescaler value for RTC. And for each time I got different results(~+/-15sec. for each 2minutes), when test it. I found note in Reference manual (7....
STM32L Nucleo clock change
Posted on January 11, 2016 at 12:08I am trying to configure the clock source in a STM32L Nucleo Board (that mounts the STM32L152RE microcontroller). I use EmBitz as IDE.I have downloaded the Excel file STM32L1xx Clock configuration tool from ST that...
help with rtc
Posted on January 10, 2016 at 16:49Hi, I'm trying the learn how to use rtc. can someone help me to understand how to inizialize rtc and how to use timestamp?i'm using stm32f103 uCthanks :)
mauro2 by Associate II
  • 1141 Views
FatFs uSDCard read Problem
Posted on January 04, 2016 at 09:51 :) Hi my friends. I've written a code to play a song file for long time on repeat mode. Normally this code work correctly without any problem but for a short time. After for number of repeated, the s...
sm by Associate II
  • 1133 Views
