STM32 MCUs Products
STM32L476 PWM generation through DMA transfer for WS2812
Posted on January 26, 2016 at 01:36 Hi guys, I am here again because I have a problem. I'm trying to control a WS2812 16xLED ring using TIM2 on the Nucleo-L476 board. I successfully communicated to the ring and for a single time I can control it...
angeletti by Associate II
  • 3314 Views
  • 6 replies
A question for Diskio_drvTypeDef USER_Driver?
Posted on January 26, 2016 at 21:24 Guys, I have question for : Diskio_drvTypeDef USER_Driver Code : /* Private function prototypes -----------------------------------------------*/ DSTATUS USER_initialize (BYTE pdrv); DSTATUS USE...
Standard Periph Library vs HAL
Posted on January 26, 2016 at 11:29Hi everybody.I confuse.I just begun study STM32 series.In a month, i studied hard STM32F3, F4 and i used Standard Perish Library.But, when i used STM32CubeMX, this application creat HAL base projects.what is better...
STM32F030CC, I2C1 busy after I2C_TransferHandling
Posted on January 26, 2016 at 16:47Hello, this is my first time on this forum. I was using STM32F030F4 for communication with battery (SMBus). I decided to change it for STM32F030CC, but it seems like my I2C1 is not working properly any more. I used...
karlis by Associate II
  • 1251 Views
  • 1 replies
STM32Cube_FW_L4 V1.2.0 bug ?
Posted on January 20, 2016 at 21:52While trying to use GPIO inputs as inputs for the ADC, I discovered that the ADC control mode was not programmed correctly in the function HAL_GPIO_Init. I replaced:         temp &= ~(GPIO_ASCR_ASC0 << position) ; ...
bas by Associate
  • 1403 Views
STM32F429 and STM32F469 FMC limitations
Posted on January 22, 2016 at 18:19Hi Does any one know the minimum lead count device I need to choose on STM32F429 to ensure it supports SDR SDRAM memory? In the datasheet it only mentions 100L can only support PSRAM and some other Flash based.I wo...
CAN busy after first transmission
Posted on January 26, 2016 at 17:40 Hi. I'm trying to make my STM32F4-Discovery talk to itsef through CAN,using this configuration and here's my code. #include ''stm32f4xx_hal.h'' #include ''stm32f4xx_hal_can.h'' #includ...
Kit Laser distance meter stm32f407 50M
Posted on July 09, 2015 at 10:30I work on a project ''distance meter kit '' Here is the link. http://asv-lab.ru/blog/fazovyj_lazernyj_dalnomer_asv50m/2015-06-26-12  There are videos. https://youtu.be/lnKYCIw8I4E https://youtu.be/Iv_juuR2Ceg In the c...
asv-lab2 by Associate II
  • 1851 Views
  • 3 replies
STM32F030F4 flash number erase
Posted on January 26, 2016 at 08:19Here on page 62 Flash memory endurance and data retention 1 k cycles: http://www.st.com/web/en/resource/technical/document/datasheet/DM00088500.pdfHere on page 14, 10 000 times: http://www.st.com/st-web-ui/static/a...
9056766 by Associate II
  • 1201 Views
