STM32 MCUs Products
STM32F4: Using several ADCs independent
Posted on May 28, 2016 at 12:59Hello, I wonder if it is or it is not possible to use more than one ADC independet of each other. My problem is as follows: I want to use ADC1 and ADC2 in dual mode and ADC3 in independent scan conversion mode. I can s...
STM32F767 examples / support
Posted on May 03, 2016 at 14:08Hi,any idea when support for these is out? I've got a 767ZI... I whacked on a nucleo board and would like to check out some DP FPU stats,regards
tau by Associate II
  • 3481 Views
  • 14 replies
Interrupt on PE2 not working
Posted on May 27, 2016 at 20:49Hi, I'm working on a STM321F407IG MCU and trying to get interrupt working on pin PE2. I'm using HAL Library and got INterrupts Working on some of the other pins but not on PE2. In GPIO Configuration I set Mode of the ...
RTC_CR Daylight Saving
Posted on May 26, 2016 at 18:05 Hello, Looking at the RM0090, I can read on the RTC_CR register description : Bit 17 SUB1H: Subtract 1 hour (winter time change) When this bit is set outside initialization mode, 1 hour is subtracte...
STM32CubeMX for STM32F769
Posted on May 18, 2016 at 12:38Hi,anyone know when the STM32F769 (inc STM32F769I-DISCO & STM32F769I-EVAL boards) will be supported in CubeMX ?
daemynnur by Associate II
  • 1950 Views
  • 5 replies
STM32F7: New devices & development boards
Posted on May 27, 2016 at 11:48New http://www.st.com/content/st_com/en/products/microcontrollers/stm32-32-bit-arm-cortex-mcus/stm32f7-series.html?querycriteria=productId=SS1858&icmp=tt3649_gl_pron_may2016 are based on the high-performance ARM®Cortex...
ST-Link Utility can't program OTP memory
Posted on May 24, 2016 at 07:33Hi all,We can't seem to program any memory in the OTP memory range on the F7 series (STM32F746VG). We are trying to program in the address range of 0x1FF0F000 onwards.When we do we get an error ''Error occured during m...
ltaylor9 by Associate II
  • 3840 Views
  • 7 replies
CubeMX 4.15.0 download link is broken
Posted on May 27, 2016 at 06:52The MacOS Cube 4.14 to 4.15 updater managed to wedge my copy, so I blew it away and went to the website to grab the installer for 4.15.I went through the download link/accept the license/login loop a bunch of times, bu...
