STM32 MCUs Products
Resolved! STM not respecting recommended design guide for HSE crystal
Posted on August 16, 2017 at 18:24I am trying to choose a crystal for the STM32F7. The only problem being is that I cant find a component that respects the recommended values found in the following arm http://www.st.com/content/ccc/resource/technica...
Maz D by Associate II
  • 3912 Views
  • 8 replies
Need Help For CS43L22 On STM32F4 Discovery DK
Posted on August 17, 2017 at 17:071. As I see on stm32f4 discovery DK schematic, CN4(audio jack) only connect to HP/LINE_OUTA and HP/LINE_OUTB ( Pin 14 and 15 of CS43L22). Because of that, I only use OUTPUT_DEVICE_HEADPHONE of CS43L22. Does my thoug...
gcc and PCROP
Posted on August 17, 2017 at 12:59Dear all,the readout protection of the L4, F4 and F7 MCUs is supported with build-tools form Keil and IAR. The 3 application notes, i have read, states that one of these IDEs must be used. Since the newer arm-none-e...
I can't install library to STM32CubeMX
Posted on May 11, 2017 at 22:45Hello,İ just downloaded a library for STM32CubeMX, i just gave library's link below. I just can't install it to Cube. I'm opening the new library manager by clicking install new libraries in help and then clicking the...
Cryistal choice
Posted on August 16, 2017 at 09:04HelloI use stm32f030p4 .I confused about select appropriate for HSE.I want use maximum speed of MCU(48mhz) and i saw at datasheet i can use crystal between 4-32mhz .How much crystal is the best for my work(Accurate)...
Resolved! Unable to download X-CUBE-CRYPTOLIB
Posted on August 08, 2017 at 02:27Hello,I have been attempting to download the X-Cube-Cryptolib for some time, and have been unable to. I have tried filling out the form, which changes the button to 'Validate'. Later on when I check on the status, t...
T H by Associate II
  • 4314 Views
  • 11 replies
STM32f429II revisions and Errata fix confirmation
Posted on August 17, 2017 at 12:22Hello,As per the STM32F42xx errata sheet (/external-link.jspa?url=http%3A%2F%2Fwww.st.com%2Fcontent%2Fccc%2Fresource%2Ftechnical%2Fdocument%2Ferrata_sheet%2F38%2Fe6%2F37%2F64%2F08%2F38%2F45%2F67%2FDM00068628.pdf%2Ff...
Krishna M by Associate II
  • 1381 Views
  • 1 replies
How can the linker lose HAL_StatusTypeDef ?
Posted on February 15, 2017 at 00:17This was all running before I added my old code RecordStorage.cpp*** Using Compiler 'V5.06 update 4 (build 422)', folder: 'C:\Keil_v5demo\ARM\ARMCC\Bin'Build target 'C091_V12CubeConfig2'compiling RecordStorage.cpp...
T J by Lead
  • 5133 Views
  • 10 replies
