STM32 MCUs Products
STM32L4 Continous ADC DMA Multi-Channel Data Processing
Posted on January 31, 2018 at 06:57 Good Day I have an ADC Configured for Continous conversion with DMA. I Periodically stop it and quickly process the data before starting it again. I would like to know how to process the data if I enable ...
abotha by Associate III
  • 1891 Views
Resolved! STM32L151C8T6 RTC Alarm A interrupts
Posted on May 26, 2017 at 01:19 Hello. I'm trying to use the RTC Alarm interrupt to execute code at a specific time interval. I did everything, but the interrupt code never gets executed. However, all registers seems to be properly set. Fin...
kaloyan by Associate III
  • 1765 Views
stm32f767zit6 memory card interface PINS
Posted on February 01, 2018 at 03:12hi, I am using this stm32f767ZIT6 CPU for development.I want to know which are the pins for Memory card interface?I want to use 4-bit SDMMC card interface.-Thanks#stm32-mmc #sd-cards #nucleo-stm32f7
Resolved! Static library error
Posted on February 01, 2018 at 03:54Hello,I want to use the S2LP_Sigfox_DK library. The version is 1.3.0.When I add the static library into my new project that is made by CubeMX, some compile error occurred.Let me know what should I do.What did I do...
HAL USB host HS in FS with FreeRTOS
Posted on June 19, 2015 at 10:22Hi all,I'am communicating with a 3G modem through USB. I'am using FreeRTOS (this is important).The USB is configurated like :  /*Set LL Driver parameters */  hhcd.Instance = USB_OTG_HS;  hhcd.Init.Host_channels = 11; ...
vincent2 by Associate II
  • 2469 Views
  • 4 replies
USB TID?
Posted on January 24, 2018 at 09:38Any one know what is USB TID? And, have some one know how to get the ST USB TID number?
Resolved! How to link a static library?
Posted on January 31, 2018 at 16:29Hello,Let me know how to link a static library.I made a PCB with STM32L0, and use keil uVision5 environment.I want to use a static library like 'xx.a', but I don't know how to link it.I checked 'Options for Target'...
STM32F4 HSI Accuracy/drift
Posted on January 31, 2018 at 17:42I am looking at rev 8.0 of DS8597, the datasheet for the STM32F417 micro and trying to reconcile two competing specifications for the absolute accuracy of the 16 MHz internal RC oscillator. Section 2.2.12 plainly s...
