STM32 MCUs Products
STM32F4 Endianess and 24 bit data
Posted on April 29, 2018 at 02:12Hi, trying to get I2S working with 24 bit data. The function call HAL_I2S_Transmit takes a pointer to unsigned 16 bit var so there needs to be 2 transfers to get 24 bits into the I2S. I am using an unsigned 32 bit va...
Hard fault after first JPG with 746D
Posted on June 06, 2018 at 21:40 I am building code to show all jpeg images in SD card and print their names. I use the STM32F746 Discovery. The jpeg decoder crashes after the first image. The Jpg decoder stays at hard fault loop. If I comment the ...
LMI2 by Lead
  • 3051 Views
  • 10 replies
SDMMC status flags
Posted on June 10, 2018 at 23:14Hi,I am using the SDMMC module of the STM32F767ZI to read data from SD cards.In general everything seems to work but I have some problems because I am getting CRC errors when reading 512 byte data blocks from the SD c...
Newbie loSTM in space
Posted on June 08, 2018 at 12:34Hi,sorry for this beginner question: I am new to developping with the STM32 platform.I just acquired an STM32F103 evaluation board and the Atollic TrueStudio software.This works perfectly, I could compile and execute ...
Hardware 2D DMA with color key
Posted on June 10, 2018 at 01:35Hi,I'm using 2D DMA to draw sprites on the screen, but there is a surronding black color around the sprites.So I have enabled the layer color key, and its not working, still there is a black rectangle around it.BSP_LC...
STM32F7 Discovery?
Posted on September 30, 2014 at 15:43Hello, will ST offer a STM32F7 discovery board? If yes, when can we expect it? Regards
mfkfx1 by Associate
  • 11218 Views
  • 36 replies
General questions about STM32F7 Discovery board.
Posted on January 07, 2016 at 21:31http://www.st.com/web/en/catalog/tools/FM116/SC959/SS1532/LN1848/PF261641?icmp=pf261641_pron_pr-massmarket_jun2015&sc=stm32f7discovery-pr♯Now, I have spent just about all day looking for this one, but to no result....
lwIP - use of makefsdata
Posted on November 02, 2017 at 14:29Hi all,i'm trying to customize html files that are hosted in a webserver running on my st32 nucleo f676zi with lwIP library.The big issue is that i can't understand the correct usage of makefsdata script.Actually,...
Di Ci by Associate II
  • 2918 Views
