STM32CubeMX (MCUs)
Ask questions on STM32CubeMX. Discuss code generation and configuration challenges, among other topics.
STM32CubeMX 6.17.0 released
We are pleased to announce that version 6.17.0 of STM32CubeMX is available. What is new in 6.17.0: Added support for new microcontrollers across the STM32WBA, STM32H5, and STM32U3 seriesAdded support for new boards: NUCLEO-WBA25CE1, NUCLEO-H5E5ZJ, ST...
Aimen1 by ST Employee
  • 1628 Views
  • 0 replies
  • 2 kudos
STM32CubeMX UART LL Driver issues
Hello,I had earlier raised the concern on STM32CubeH7 GitHub page ( https://github.com/STMicroelectronics/STM32CubeH7/issues/69 ). However they asked me to raise the concern on this forum.I am observing following function calls missing from MX_UART8_...
Resolved! STM32CubeMX MDK-ARM project generation failure
Windows 10 64bit - STM32CubeMX 6.0.1 - STM32H7B3LIHxQ MCUAttempting to generate a fresh project and get the below error. Any thoughts on how to resolve the issue? project file attached. Thanks!
Just Matt by Associate III
  • 4711 Views
  • 9 replies
MX Init functions overwrite static size_t variable
I am working on an embedded application using the STM32F103C8T6 (black pill). I've been slowly adding the functionality I need and adding different peripherals one by one. For USART I was using the excellent code written by Tilen Majerle here. Everyt...
SStru.1 by Associate II
  • 2028 Views
Resolved! Not seeing full DMA Initialization with CubeMx
With CubeMx, I've set up the DMA in Circular Mode, Data Width Half Word, Increment Address Memory. When I get the generated code, I only see the code below. Where are the other initialization parameters? Is it because the DMA channel interrupt is ena...
xpp07 by Senior
  • 1548 Views
  • 1 replies
STM32CubeMX bug preventing to use the LED output (PC13) on STM32F103/BluePill + bug in SVD file for STM32F103
I am using a Chinese low-cost "Blue Pill" board with an STM32F103C8T6, and developping in EmBitz IDE using init code generated by STM32CubeMX. On this board, the PC13 output is connected to an LED, but the code generated by STM32CubeMX will not allow...
Resolved! How do you install X-CUBE-Azure STM32Cube extension pack?
Hi,I am trying to install the X-CuBE-Azure expansion for STM32Cube. See expansion packages page: https://my.st.com/content/my_st_com/en/products/embedded-software/mcu-mpu-embedded-software/stm32-embedded-software/stm32cube-expansion-packages/x-cube-a...
PSarr.1 by Associate II
  • 2127 Views
