What's the difference STM32CubeMx and STM32CubeF7? STM32F7x can be set using STM32CubeMX, but is it insufficient?
TMATS.1
Imen.D
Hello @TMATS.1​ ,
STM32CUBEMX is a graphical software configuration tool that allows fast and easy microcontroller configuration (pins, clock tree, peripherals, middleware) and generation of the corresponding initialization C code using graphical wizards. For more details, Please, refer to STM32CubeMx user Manual UM1718.
STM32Cube firmware is a complete embedded software package include: hardware abstraction Layer (HAL) and Low-Layer (LL) APIs and a consistent set of middleware components: USB, FATFS, FreeRTOS, graphics, TCP/IP...
There is an application note for each STM32Cube firmware package by device series, that illustrates the existing examples topics and packages.
For STM32F7 refer to :
  • UM1891 User manual Getting started with STM32CubeF7 MCU Package for STM32F7 Series: This user manual describes how to get started with the STM32CubeF7 MCU Package.
  • AN4731 Application note STM32Cube MCU Package examples for STM32F7 Series
  • UM1905 User Manual Description of STM32F7 HAL and Low-layer drivers
  • STM32CubeF7 firmware package presentation
Best Regards,
Imen
Imen
4 REPLIES 4
STM32CubeMX is a software you use to configure STM32 chips.
STM32CubeF7 is a repository used by STM32CubeMX to configure STM32F7 chips.
Imen.D
Hello @TMATS.1​ ,
Best Regards,
Imen
Imen
Thank you for your answer!
Thank you for your information!
