STM32 MCUs Products
RTCK,DBGREQ,DBGACK needs mandatory pulldown to ground?
Posted on July 30, 2011 at 12:46Hi, I am using a STM32F100CB part on my target. I have not pulled RTCK, DBGRQ and DBGACK down with a 10K as recommended by the App note AN2586. Presently I am not able to get Ulink2 to communicate with my target. I ge...
gopi by Associate
  • 1448 Views
Hard fault with no obvious reason why
Posted on August 03, 2011 at 18:50I'm running into a hard fault situation and I'm not sure why this is happening.From what I'm seeing in the fault status registers I'm getting...Usage fault status: INVSTATE is setHard fault status : FORCED is setDeb...
shotaro by Associate II
  • 1736 Views
DEV_TARGET_CMD_ERR on breakpoints (Rowley Crossworks)
Posted on May 30, 2011 at 01:57I've just gotten some STM32VLDiscovery boards and am attempting to program them via Rowley Crossworks.  I've got the STLink connection working and can download and run programs and view registers, etc.  But if I try to...
kk6gm by Associate II
  • 912 Views
Programming Ethernet on STM32-P107
Posted on July 21, 2011 at 10:15 Hi guys, Does anyone know how to configure the RMII mode which include the signals: TXD, TX_EN, RXD, CRS_DV, MDC, MDIO, REF_CLK. an explication, or an example configuration would be very helpful, Thanks in...
brouzi by Associate II
  • 1316 Views
  • 3 replies
ADC different channel
Posted on August 02, 2011 at 11:56Hello, I can do a ADC conversion for 1 channel. But I have a problem for using 2 channels. I do this: ADC_InitStructure.ADC_NbrOfChannel = 2; ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 1, ADC_SampleTime_13Cycles...
cyril2399 by Associate II
  • 3678 Views
  • 7 replies
STM3220G_Eval SDIO/DMA Multi_block Transfer
Posted on August 02, 2011 at 19:29Hello,I have the STM3220G_Eval board that has the STM32F207IG processor.  I have successfully ran the demo code for transferring data to and from the SD card in Single and Multi_Block mode.  For my application I nee...
rmpresto by Associate II
  • 2824 Views
  • 5 replies
Linux device driver for STM32TS60
Posted on August 02, 2011 at 23:10Hello,We're about to receive samples for this touch controller STM32TS60. As I understand it, Stantum provides the firmware with their PMatrix IP technology. Where can I get the Linux driver for this particular cont...
khbx87 by Associate
  • 743 Views
  • 0 replies
How to contact moderator ST-One32
Posted on August 02, 2011 at 20:58Hi, I've tried to contact the moderator ST-One32 via button ''Contact Moderator'' but without any response. Is ST-One32 still here? Or doesn't work this function? Regards Achim
elgerta by Associate II
  • 1097 Views
Declaration ERROR
Posted on August 01, 2011 at 14:00hello,       i m using IAR kickstart version for code limit of 32k and when i run my example code available on st website for LCD display application, i get an declaration error as :-Error[Pe147]: declaration is inc...
atul by Associate II
  • 1667 Views
