atul
Declaration ERROR
  • August 1, 2011
  • 1050 views
Posted on August 01, 2011 at 14:00
hello,
       i m using IAR kickstart version for code limit of 32k and when i run my example code available on st website for LCD display application, i get an declaration error as :-
Error[Pe147]: declaration is incompatible with ''__interwork __softfp unsigned long __REV16(unsigned long)'' (declared at  D:\atul\IAR\LCD\STM32F10x_AN2790_FW_V2.0.0\Libraries\CMSIS\Core\CM3\core_cm3.h 689
pls help me if any one can..........
#declaration-error #stm32
    Tesla DeLorean
    Guru
    August 1, 2011
    rosarium
    Posted on August 02, 2011 at 13:38
    which version IAR are you using?? 6.2??
    if yes once try this following step.
    copy the attached file at
    C:\Program Files\IAR Systems\Embedded Workbench 6.2\arm\inc\c
    ________________
    Attachments :
    intrinsics.h : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I1ID&d=%2Fa%2F0X0000000bkw%2F8um80xKNrRN3hq85BLfYJRwv5yyASrlcPzjoPtzZ594&asPdf=false
