STM32 MCUs Products
Instruction Timing for STM32F05
Posted on June 03, 2013 at 17:23Please help me find the document with instruction timings. Not found in short, datasheet, programming manual, user manual.
tech by Associate
  • 1058 Views
Errata entry needed for STM32F3
Posted on June 07, 2013 at 00:37 For DMA_CCRx, halfword and byte write access is broken. In both cases, an interrupt is generated on the instruction following the write instruction. Also, if a byte is written to [15:8], the value is replicated t...
gfuehrer by Associate II
  • 2722 Views
  • 7 replies
STM32F4 Discovery board for ethernet development
Posted on June 06, 2013 at 05:05I went through STM32F4 family and STM32F407VG is the best one which meets product requirement. As you know STM32F4 serial does not integrate ethernet physical layer. So my question is:1. please recommand the ethernet ...
STM32F373 Overrun error with SDADC using DMA
Posted on June 06, 2013 at 13:44I am using the both SDADCs configured as follows: 3 channels configured for injected conversions SDADC2 triggered when SDADC1 is triggered SDADC1 triggered from timer configured for 200 usec Both SDADC1 and 2 configur...
IAR _ stm32 f4 board => Fatal error: ST-Link, Failed to identify target MCU - Check hardware and interface selected Session aborted!
Posted on June 06, 2013 at 19:08I'm a beginer with IAR. I selected the st_link for the debugger but this error is generated :''Fatal error: ST-Link, Failed to identify target MCU - Check hardware and interface selected   Session aborted! '' I tried ...
possibly more efficient USART comm?
Posted on June 05, 2013 at 23:25I've been working on a project with an stm32f4 and the .NETMF framework. I hit a wall with the garbage collector in .NET hampering my timing abilities and so have erased the chip and gone native. My background is in C...
jonphenry by Associate II
  • 1889 Views
  • 5 replies
Not desidered auto-reload TIM2
Posted on June 06, 2013 at 00:02Hi,i'm angry with this simple code.I need that the timer2 goes from TIM2_ARR to zero and stay zero until a Update EVent is manually generated (with UG from TIM2_EGR of course).But unfortunately TIM2 seems to reset at ...
dario by Associate II
  • 3513 Views
  • 8 replies
STM32F3DISCOVERY debug problem
Posted on June 06, 2013 at 16:29Hello everyone. I've buy a new STM32F3DISCOVERY kit but I'm not debugging it with keil. When I want to start debug session it is failuring, ''Error: Flash download failure - ''Cortex-M4'''' with this error. My debug a...
LCD read issue on STM3240G-EVAL
Posted on March 29, 2013 at 22:16Does anyone have code that is able to successfully read the ID from the LCD on the STM3240G-EVAL board?  Using the ST provide examples (without LCD reads), we can write to the LCD without any issues, but when trying...
pmoore by Associate II
  • 1732 Views
  • 3 replies
FSMC Flash and SRAM recommendation
Posted on June 04, 2013 at 20:14Hi Guys, I wanna ask for a recommendation. I want to implement a Webserver to enable a Webinterface. The example Project with the server is working well. I want to store the webpage etc. on a NAND flash and I think I...
ersan by Associate II
  • 1765 Views
  • 3 replies
