STM32 MCUs Products
STM32F0 bootloader int vect tab problem
Posted on January 23, 2016 at 12:23Hi everyone,I have problem with bootloader in STM32F0. I used Coocox and I read many topics about bootloader and RAM remap on this procesor and I've done everything with this. Debug is working fine I can go inside ...
skolodzi by Associate II
  • 2884 Views
  • 7 replies
Problem with Readout Protection on STM32F4 Discovery
Posted on January 22, 2016 at 07:43I cant connect my board because of readout protection is activated (Level 1) and I cant set it back to level 0 in Option Bytes menu on ST-Link Utility. How can I disable Readout Protection  please explain in an eas...
z_ by Associate
  • 1466 Views
  • 3 replies
Measuring input from a reed switch with STM32L100RB
Posted on October 02, 2015 at 17:08I want to count pulses generated from a reed switch. The switch has three outputs connected to WKUP1, WKUP2 and PCO of the STM32L100RB. I need an example or suggestions on how to achieve this. Kindly assist.
idris by Associate II
  • 3571 Views
  • 8 replies
STM32L151 and ADC woes
Posted on January 23, 2016 at 17:10 Hi guys I'm hoping someone will be able to assist me here. I have been struggling for most of the day with simply trying to read the value of the internal temperature sensor on my STM32L I have been thr...
sschocke by Associate
  • 1000 Views
  • 0 replies
STM32 Documents management
Posted on January 23, 2016 at 10:43Hi all,I've downloaded all documents of STM32 microcontrollers from ST website and organized them locally to access them quickly; however I am concerned about keeping track of changes and new version of them. Is th...
rezaxyz by Associate II
  • 598 Views
  • 0 replies
32f429i-discovery firmware upgrade
Posted on January 21, 2016 at 20:26When we have tried firmware upgrade process according to the sample bin file. (STM32F429I-Discovery_LTDC_ColorKeying_0x08020000.bin) , it works well. But when we compile LTDC_ColorKeying sample codes and generate b...
bhakan by Associate II
  • 1416 Views
  • 3 replies
Partitioning with FATFS
Posted on January 22, 2016 at 17:56Does anyone have any experience with multiple partitions in fatfs? I'm trying to create two partitions on an SD card with it, and I'm not convinced it's doing it correctly. I might be misunderstanding some things (...
STM32L152ZDT Eval and Profiling tools
Posted on January 21, 2016 at 08:27Hi,I have the Evaluation board STM32L152D-EVAL. I powered it on using USB Type-B connection on CN13. I am able to program the flash using Keil uVision 5 and also able to debug the code using the same. Currently I a...
dhaval by Associate II
  • 875 Views
