STM32 MCUs Products
How do you structure folders for a project?
Posted on March 06, 2017 at 04:54I notice that in the example projects within the STM32L4 firmware package that all the examples have a parent folder that contains a SRC folder with the C files, and INC folder with the local include files, and a pro...
Resolved! STM32F4 Hard Crashes with I2C
Posted on March 06, 2017 at 16:22I'm having a problem where I2C is hard crashing my STM32F446RET6 (programmed in EWARM with CubeMX as a starting point).  When I2C devices are enabled, at random amounts of time (couple hours to overnight), a .25 seco...
joesnyder by Associate III
  • 1905 Views
  • 3 replies
ITM_SendChar, ST-Link/V2 and Eclipse/gdb
Posted on October 03, 2012 at 03:58Hi, Is anyone getting debug text via ITM_SendChar using ST-Link, gdb, and Eclipse? I've tried it for the first time, and I'm not seeing my debug text displayed in the Eclipse console view. I can confirm with breakp...
RTC on STM32L053R8
Posted on March 06, 2017 at 05:49I tried to work with RTC (LSI) on STM32L0 but I got a problem. My desire is run a RTC like normal watch and get time at 2 point and find time between 2 point in milisecs but when I get time debugger always give me 0x...
Software Interrupt NVIC
Posted on February 27, 2017 at 19:51I can not find enough information about the definition of a software interrupt with NVIC. If the edge of an internal software bit is positive, an interrupt routine should be executedThanks#stm32f4
Resolved! What is the minimum clock speed if I use ADC with DMA?
Posted on March 03, 2017 at 20:18I use STM32L151 for digitizing 3 values: Vrefint, Temp.sensor and 1 external source. Program uses sleep mode.I get garbage after switching CPU freq from 250 kHz to 4 mHz and correct values when switching from 500 kHz...
Resolved! Is I2C on STM32L4x6xx usable?
Posted on March 04, 2017 at 10:53Hi,I am trying to understand the errata sheet for STM32L4x6xx series of MCU (DocID026121 Rev 4, December 2016).I2C peripheral limitations section lists one of the silicon bugs as�2.6.3 Wrong data sampling when data s...
