STM32CubeMX (MCUs)
Ask questions on STM32CubeMX. Discuss code generation and configuration challenges, among other topics.
STM32CubeMX 6.17.0 released
We are pleased to announce that version 6.17.0 of STM32CubeMX is available. What is new in 6.17.0: Added support for new microcontrollers across the STM32WBA, STM32H5, and STM32U3 seriesAdded support for new boards: NUCLEO-WBA25CE1, NUCLEO-H5E5ZJ, ST...
Aimen1 by ST Employee
  • 1626 Views
  • 0 replies
  • 2 kudos
CubeMX install on Mac Sierra
Posted on December 06, 2016 at 09:52I am trying to install CubeMX 4.18.0 on my Mac (Sierra), opening the installer appears to do nothing, if launched via spotlight i get a warning stating unable to open the programm.#cubemx #macos #sierra
FREE_RTOS
Posted on May 24, 2018 at 12:53Hey,I am getting started with FreeRTOS on NUCLEO-FO72RB.i set UART communication using DMA.i would like to writre tu UART from muliple taske using queue with size of 16 items;so i created 3 tasks.- one task1 to receive...
C++ interrupts from cubeMX generated project
Posted on May 25, 2018 at 04:37I have discovered that renaming stm32f4xx_it.c to stm32f4xx_it.cpp in sw4stm32 causes interrupts to no longer work even after converting the project to C++.I have attached a minimum project for sw4stm32 that demonstrat...
Resolved! Generate conditional Init with CubeMX
Posted on May 22, 2018 at 21:29Hi,Is there a way to generate a condition inside the initialization code generated by CubeMx in TrueSTUDIO?I want to do something like this inside the MX_SPI2_Init() :    if (HAL_GPIO_ReadPin(GPIOI, GPIO_PIN_11) == GPI...
Bug On CubeMX 4.20.1? STM32F407 Triple Mode and DMA
Posted on April 07, 2017 at 16:53Hi all!I want to you use all of the ADC of the STM32F407VG in triple regular simultaneous mode and to save a buffer of samples in RAM with DMA.I configure everything with CubeMX and when I debug it, I cannot access m...
CubeMX generated code does not seem to compile in EWARM
Posted on January 25, 2018 at 12:27CubeMX 4.24.0 generated code does not seem to compile in EWARM 7.60.1.I am trying to create code to set up a STM32F071C8Tx.I get lots of errors relating to __DSB, __WFI, __WFE and __SEV saying cannot call intrinsic...
