STM32CubeMX (MCUs)
Ask questions on STM32CubeMX. Discuss code generation and configuration challenges, among other topics.
STM32CubeMX 6.17.0 released
We are pleased to announce that version 6.17.0 of STM32CubeMX is available. What is new in 6.17.0: Added support for new microcontrollers across the STM32WBA, STM32H5, and STM32U3 seriesAdded support for new boards: NUCLEO-WBA25CE1, NUCLEO-H5E5ZJ, ST...
Aimen1 by ST Employee
  • 1578 Views
  • 0 replies
  • 2 kudos
bug in stm32cubemx 4.23 makefile generator
Posted on November 19, 2017 at 21:26(I'm sorry if this is the wrong place to report this)STM32CubeMX 4.23 (tested with MacOS High Sierra, Arch Linux x86_64 with x32 binary emulation) is generating spurious entries during Makefile generation (such as...
CubeMX adc rank number bug
Posted on May 30, 2018 at 14:33Hello there,When configuring an ADC periph (STM32L452) the ranks are assigned incorrectly. Cube generates this:sConfig.Rank = 1;sConfig.Rank = 2;// etcInstead of this:sConfig.Rank = ADC_REGULAR_RANK_1;sConfig.Rank = AD...
about STM32CubeMx question
Posted on June 01, 2018 at 05:35STM32CubeMX generate code in keil5 ,when project into debug environment ,why no periphral register window?#stm32cubeprogrammer
ann Qian by Associate
  • 902 Views
  • 1 replies
Resolved! STM32CubxMX software
Posted on June 01, 2018 at 05:43what the advantage and convienient of STM32CubxMX  generate Code in keil5 compare to classic library? Is there some documents for user about STM32CubxMX  generate Code ? The principle of STM32CubxMX  generate Code is ...
  • 1049 Views
  • 1 replies
USB CDC breaks on heavy load
Posted on May 30, 2017 at 19:08Hi,I'm currently evaluating the STM32F072 Discovery. We are tending moving from ATXMega to ARM and I have to verify if the device is fitting our needs, before investing more time in learning a new architecture.I succes...
Klaus U by Associate
  • 2991 Views
  • 3 replies
STM32H743 TIM2 input compare
Posted on May 19, 2018 at 10:48Hi,I can not get the input compare mode working as expected. I need to use TIM2 CH1 as trigger to measure the frequency of external pulses. I have used the methode on a STM32F091 where it works fine.RCC and GPIO are in...
CubeMX install on Mac Sierra
Posted on December 06, 2016 at 09:52I am trying to install CubeMX 4.18.0 on my Mac (Sierra), opening the installer appears to do nothing, if launched via spotlight i get a warning stating unable to open the programm.#cubemx #macos #sierra
FREE_RTOS
Posted on May 24, 2018 at 12:53Hey,I am getting started with FreeRTOS on NUCLEO-FO72RB.i set UART communication using DMA.i would like to writre tu UART from muliple taske using queue with size of 16 items;so i created 3 tasks.- one task1 to receive...
