STM32CubeMX (MCUs)
Ask questions on STM32CubeMX. Discuss code generation and configuration challenges, among other topics.
STM32CubeMX 6.17.0 released
We are pleased to announce that version 6.17.0 of STM32CubeMX is available. What is new in 6.17.0: Added support for new microcontrollers across the STM32WBA, STM32H5, and STM32U3 seriesAdded support for new boards: NUCLEO-WBA25CE1, NUCLEO-H5E5ZJ, ST...
Aimen1 by ST Employee
  • 1578 Views
  • 0 replies
  • 2 kudos
The system time
Posted on August 05, 2016 at 11:56I wanted to try out the CubeMX. I'm a bit stuck with some time issues. In standard peripheral I used system_get_time();What is the equivalent of this function in CubeMX?I found HAL_RCC_GetHCLKFreq(); that could be i...
CubeMx STML0 USB Hid Bug
Posted on August 04, 2016 at 10:36Hi everyone, I developed STM32L0 USb hid application with Cubemx,I send to data computer with usb hid interface.But I cannot send ascii zero(null )character.Other character send succesfully. For example my buffer li...
CubeMX and FreeRTOS : USE_RTOS set to 0 ???
Posted on July 29, 2016 at 16:10We use CubeMX .We have selected ''FreeRTOS''In the file ''stm32l4xx_hal_conf.h''  ''USE_RTOS'' is set to 0.See the following line:&sharpdefine  USE_RTOS                     0U It seems strange .the goal was to modify ...
gillou by Associate
  • 1010 Views
  • 0 replies
micro SD Card Programming on STM32F7 Discovery Board
Posted on July 28, 2016 at 19:10Hello,           https://www.youtube.com/watch?v=kRhF44v2ezMhttp://https//www.youtube.com/watch?v=kRhF44v2ezM https://www.youtube.com/watch?v=kRhF44v2ezM The initialization code was generated using STM32CubeMx  #sd...
Posted on July 28, 2016 at 19:06Hello,            https://www.youtube.com/watch?v=kRhF44v2ezM https://www.youtube.com/watch?v=kRhF44v2ezM The initialization code was generated using STM32CubeMx  #stm32cubemx #mmc #sd-card
Any way to change processor in CUBE?
Posted on July 25, 2016 at 22:02We have spent weeks getting the CubeMX setup just right, and have decided that we need a processor that has more memory. I really don't want to start from scratch, the processor is almost identical except that it has ...
mattreed9 by Associate III
  • 2240 Views
  • 1 replies
Resolved! CubeMX, missing device-setting in generated EWARM project
Posted on July 13, 2016 at 04:05Hi, I encountered following. When I set device type as ''ST STM32F401xE'' on EWARM, the project was build successfully. Is the device type should determined everytime? with,   STM32CubeMX Version 4.15.1   STM32Cube FW...
