STM32CubeMX (MCUs)
Ask questions on STM32CubeMX. Discuss code generation and configuration challenges, among other topics.
STM32CubeMX 6.17.0 released
We are pleased to announce that version 6.17.0 of STM32CubeMX is available. What is new in 6.17.0: Added support for new microcontrollers across the STM32WBA, STM32H5, and STM32U3 seriesAdded support for new boards: NUCLEO-WBA25CE1, NUCLEO-H5E5ZJ, ST...
Aimen1 by ST Employee
  • 1592 Views
  • 0 replies
  • 2 kudos
Resolved! CubeMX 6.15 does not regenerate code
Hi all,I recently updated the IDE to v1.19 and MX to v6.15.0, and the MX code generation is no longer working for me.After some testing, I found out I can create new projects and code is (apparently) well generated. After this first generation, if i ...
ACC by Associate II
  • 706 Views
  • 4 replies
  • 1 kudos
Resolved! STM32F107+Ethernet+Lwip no longer an option?
STM32CubeIDE Version 1.19.0Build: 25607_20250703_0907I created a project using the STM32F107 and Ethernet. Everything was setup using the .ioc template with Ethernet and various GPIO stuff. Lwip was not included. I generated the code and all of the E...
Starting a new project from a board NUCLEO-F767Zi
Hi,Using STM32CubeMX version 6.15.0When I start a new project from the NUCLDO-F767ZI board I just get a blank chip, none of the component configuration at all, I tried it on two PC's both the same.This used to work and was quite handy starting a new ...
Resolved! USB_OTG_HS grayed out for STM32U595VJT6
Hey! I'm trying to get USB up and running on a STM32U595VJT6. From the reference manual, it says it's supported.   However, when in STM32CubeMX, the USB_OTG_HS is grayed out. This is on a fresh project, so there's no pin conflicts or similar. This is...
bartosz_ by Associate II
  • 508 Views
  • 3 replies
