STM32CubeMX (MCUs)
Ask questions on STM32CubeMX. Discuss code generation and configuration challenges, among other topics.
STM32CubeMX 6.17.0 released
We are pleased to announce that version 6.17.0 of STM32CubeMX is available. What is new in 6.17.0: Added support for new microcontrollers across the STM32WBA, STM32H5, and STM32U3 seriesAdded support for new boards: NUCLEO-WBA25CE1, NUCLEO-H5E5ZJ, ST...
Aimen1 by ST Employee
  • 1572 Views
  • 0 replies
  • 2 kudos
very slowly initialisation of SD
Code generated by CubeMXstatic void MX_SDMMC1_SD_Init(void) {   /* USER CODE BEGIN SDMMC1_Init 0 */   /* USER CODE END SDMMC1_Init 0 */   /* USER CODE BEGIN SDMMC1_Init 1 */   /* USER CODE END SDMMC1_Init 1 */ hsd1.Instance = SDMMC1; hsd1...
EEuge by Senior
  • 972 Views
  • 1 replies
Resolved! BUG Found: Cannot have Multi mode on STM32F373
Hi!I want to report a bug.I tried SDADC and I found a bug.Also it should stand "Multi mode" not "Mulimode" and the STM32CubeIDE 1.5.0 (I'm using) missing calibration options in the STM32CubeIDE project starter. To solve this issue. Write this code in...
DMårt by Lead
  • 2047 Views
  • 3 replies
CUBEMX - cannot set 1Mb/s
Hello, I can not set 1MB/s baudrate on CAN peripheral. Used configuration on pictures. It looks like the rounding error. It worked in the previous version of CUBEIDE (1.4.0).
PDoub.1 by Associate
  • 1596 Views
  • 3 replies
Resolved! Error with custom baudRate cubeMX 6.1.1 [solved]
Hi,To configure my uart baud rate i use a variable on cube MX. To disable error i select "no check" in option --> that work find on previous version.Now with version 6.1.1 the error stay even if i select "no check" with the version 6.1.1.If you have ...
MLE S.1 by Associate III
  • 2321 Views
  • 4 replies
How to configure Sigma Delta ADC 16-bit in STM32CubeIDE
Hi!I think there is a lack of information to configure a Sigma Delta ADC 16-bit in STM32CubeIDE and I want to configure:2 Single ended zero reference3 Differential endedSo I have a lot of questions for the STM32 Team here.I begin first to configure o...
0693W000006EzhIQAS.png 0693W000006EzljQAC.png 0693W000006EzmNQAS.png 0693W000006EzzlQAC.png
DMårt by Lead
  • 6450 Views
  • 1 kudos
