STM32F746ZET6 || Technical Query
MKUMA.13
Hi Team,
Greetings of the day.
We are using the STM32F746ZET6 controller from STM.
We are using all the timers for our development.
While configuring that timer we faced some conflict errors on that. Kindly help us on this to solve the issue.
1. We are configuring the Timer 5_CH1 in normal mode
2. Then we configure the Timer8_CH8 with PWM and Output compare mode. (in both the modes we need to set the internal clock).
3. We are getting the conflict error as ( Clock source conflict error with TIM5)
Refer: Error images are attached with this mail.
Query: We are not using the internal clock for Timer 5 but it shows the conflict error with Timer 8.
Kindly help us on this issue.
Peter BENSCH
are you able to post the IOC file here to check it?
Best regards,
/Peter
