STM32CubeMX (MCUs)
Ask questions on STM32CubeMX. Discuss code generation and configuration challenges, among other topics.
STM32CubeMX 6.17.0 released
We are pleased to announce that version 6.17.0 of STM32CubeMX is available. What is new in 6.17.0: Added support for new microcontrollers across the STM32WBA, STM32H5, and STM32U3 seriesAdded support for new boards: NUCLEO-WBA25CE1, NUCLEO-H5E5ZJ, ST...
Aimen1 by ST Employee
  • 1572 Views
  • 0 replies
  • 2 kudos
cubeMX generated project, compiling main.cpp using Makefile
Hi, I try to change compiling code method to Makefile. I'm using generated from cubeMX makefile with few changes. Everything works file when I compiling main.c file but, when I change file to main.cpp compiler print errors. I tried to fix this but, m...
JuniorSTM by Associate II
  • 4057 Views
  • 4 replies
Is it possible to use LQFP packaged STM32H75x with ethernet?
I am starting to design a simple testboard using STMH75x in LQFP package with ethernet. I don't want to design a BGA board.Is that possible. I tried same pins into with CubeMx as in Discovery board, but CubeMx did not fully accept those pins for ethe...
LMI2 by Lead
  • 1011 Views
Resolved! What does System clock and To Power mean???
1 . what does means System Clock in MCU?does it mean electronic device in a MCU that issues a steady high-frequency signal that synchronizes all the internal components?​I want the exact meaning of System clock.2 . what is To Power(MHz) SYSCLK ​in Cl...
MYu.1 by Associate II
  • 1374 Views
  • 3 replies
Resolved! HardFault_Handler() error: Why the generated code try to read address beyond valid memory range on 0xfffffffd?
So I tried to implement USB Host via USB_OTG_HS peripheral. I enable all the interrupts under NVIC setting (as I don't understand which one to choose). When I attach my USB stick, it is able to detect the USB, the user callback USBH_UserProcess() is ...
BParh.1 by Senior III
  • 9917 Views
  • 8 replies
