STM32CubeMX (MCUs)
Ask questions on STM32CubeMX. Discuss code generation and configuration challenges, among other topics.
STM32CubeMX 6.17.0 released
We are pleased to announce that version 6.17.0 of STM32CubeMX is available. What is new in 6.17.0: Added support for new microcontrollers across the STM32WBA, STM32H5, and STM32U3 seriesAdded support for new boards: NUCLEO-WBA25CE1, NUCLEO-H5E5ZJ, ST...
Aimen1 by ST Employee
  • 1626 Views
  • 0 replies
  • 2 kudos
stm32CubeMX not listing Documents contents on Mac Tahoe
I recently switched to Mac Tahoe 26.1 and it seems since then stm32CubeMX 6.15 is not listing the contents of my Documents folder anymore. It doesn't seem like a rights management issue sincethere were no changes to the Documents rightsthey are ident...
SloBlo by Associate II
  • 1549 Views
  • 12 replies
  • 8 kudos
cubeide 2.0 UI error
as the image, after code generate in MX, instances chooser UI's graphic resolution is broken. I cannot choose any botton and projects. please solve it.
cm_lee by Associate
  • 338 Views
  • 1 replies
Resolved! FMC on STM32H755 data/address
Hi, may I confirm whether the STM32H755 supports only the muxed PSRAM configuration? I want to experiment something with an unmuxed connection with separate data and address. Is there a work around on this or is it an internal design that I cannot ch...
Use en.x-cube-cryptolib in stm32cubemx
Posted on November 09, 2016 at 15:03Hello,as I understood, x-cube-cryptolib is a plugin for the cubemx software, isn't it?But when I run SRM32CubeMX, Version 4.17.0 and use Help->Install new libraries-> from local and select en.x-cube-cryptolib.zip,...
Resolved! OCTOSPI Multiplexed setting gone after IDE/MX update
This morning I updated my CubeIDE to 1.19 from 1.18.  I assume MX updated too... don't know how to check the MX version.After updating and then opening and migrating my project to 1.19, my OCTOSPI settings and the "octospi.c" file were gone.  When I ...
SJR1 by Associate II
  • 888 Views
  • 6 replies
  • 2 kudos
