STM32CubeMX (MCUs)
Ask questions on STM32CubeMX. Discuss code generation and configuration challenges, among other topics.
STM32CubeMX 6.17.0 released
We are pleased to announce that version 6.17.0 of STM32CubeMX is available. What is new in 6.17.0: Added support for new microcontrollers across the STM32WBA, STM32H5, and STM32U3 seriesAdded support for new boards: NUCLEO-WBA25CE1, NUCLEO-H5E5ZJ, ST...
Aimen1 by ST Employee
  • 1547 Views
  • 0 replies
  • 2 kudos
STM32CubeMX 6.16.0 - questions
Following the article Security:How to start with STM32CubeMX Secure Manager on STM32H57 - stm32mcu I'm stuck in the step 3.2 Boot Path Configuration. At this point, STM32CubeMX had grayed out the button "Select" in Boot Path Selection. It is released...
Marcos3 by Associate II
  • 602 Views
  • 1 kudos
STM32CubeMX 6.16.1 released
We are pleased to announce that the minor version 6.16.1 of STM32CubeMX is available. What is new in 6.16.1: This release addresses and resolves the issues outlined below: Users of STM32CubeMX version 6.13.0 and later may encounter a HardFault except...
  • 1868 Views
  • 0 replies
  • 1 kudos
Resolved! STM32CubeMX does NOT work in quiet mode
Follow-on from CubeMX code generation from command line.I am posting again in hopes of getting meaningful answer.I tried creating a simple script text file to automate code generation for my project. The script file has all of three lines:config load...
Resolved! STM32C071 ADC ranking missing in CubeMx
A new question moved from this thread. Thank you a lot! But still I have many questions regarding this. Like this one: I have configured the ADC with the Temperature Channel and Vref int channel to be used with DMA. However in many examples they show...
Resolved! STM32CubeMX(6.15.0) bug for NUCLEO-H723
In the STM32CubeMX configuration interface, there are two identical options here.They can be configured into different options.After generating the code, it will be based on the configuration of the second option.
istery_0-1757838266221.png istery_1-1757838420502.png istery_2-1757838480946.png
istery by Associate II
  • 629 Views
stm32CubeMX not listing Documents contents on Mac Tahoe
I recently switched to Mac Tahoe 26.1 and it seems since then stm32CubeMX 6.15 is not listing the contents of my Documents folder anymore. It doesn't seem like a rights management issue sincethere were no changes to the Documents rightsthey are ident...
SloBlo by Associate II
  • 1439 Views
  • 12 replies
  • 8 kudos
cubeide 2.0 UI error
as the image, after code generate in MX, instances chooser UI's graphic resolution is broken. I cannot choose any botton and projects. please solve it.
cm_lee by Associate
  • 321 Views
  • 1 replies
