STM32CubeMX (MCUs)
Ask questions on STM32CubeMX. Discuss code generation and configuration challenges, among other topics.
STM32CubeMX 6.17.0 released
We are pleased to announce that version 6.17.0 of STM32CubeMX is available. What is new in 6.17.0: Added support for new microcontrollers across the STM32WBA, STM32H5, and STM32U3 seriesAdded support for new boards: NUCLEO-WBA25CE1, NUCLEO-H5E5ZJ, ST...
Aimen1 by ST Employee
  • 1547 Views
  • 0 replies
  • 2 kudos
Trouble working on KeilUVision with NUCLEO-H743ZI2
Hi There,I have been working on NUCLEO-H743ZI2 and trying to open with KEIL IDE but it direct me to use STM32CubeMX . what would be the main reason?I'm adding error message to here.thanks and best regards for your support.
MTARH.1 by Associate II
  • 1476 Views
  • 1 replies
How to install Cube extensions.
(Sorry CubeMX)Anyway. I've downloaded en.x-cube_classb.zip and sbsfu, and en.x-cube_mems1.zip and I've never managed to convince Cube to pull them in.When I try (no documentation as to how) with <Help><Manage embedded software packages><STMicroelect...
Resolved! replaced old code when update GPIO inform
Hi everyone, I have problem when i try to change GPIO inform then i push "generate code". But it replace my old code.can you let me know how to only update inform for code not replace old code?thanks you and sory about my poor english!
KUSAGI by Associate II
  • 1864 Views
  • 3 replies
I am getting hundreds of errors : HAL_Status_Typedef, HAL_LockTypedef and HAL_TickFreq_TypeDef undefined in many .h files, yet stm32f7xx _hal.h and stm32f7xx_hal_def.h are included in the .h files. How can I fix this, please ?
I have generated a project for the STM32f769 Discovery board using STM32CubeMX, to read in audio from the Line In jack, convolve the audio with a long FIR filter then output the audio to the Line Out jack. I am using the EWARM IDE. stm32f7xx_hal_d...
MLawr by Associate III
  • 1529 Views
  • 1 kudos
Resolved! stm32CubeMX corrupts Makefile during re-write
When generating code on an existing Makefile project any existing C_DEFS are corruptedC_DEFS = \ -DUSE_HAL_DRIVER \ -DSTM32F301x8 becomes-DC_DEFS = USE_HAL_DRIVER \ -DSTM32F301x8 so the definition of C_DEFS is lost and random errors result from the...
Resolved! DAC to ADC loop doesn't work
Hello,I'm working with the NUCLEO-F722ZE EVB on STM32CubeIDE.My design has a DAC output connected via a jumper wire to an ADC input (see the red wire in the attached picture.The DAC is successfully generating a sawtooth wave - verified via an oscillo...
skon.1 by Senior
  • 5899 Views
  • 8 replies
