SD Card Cannot be mounted successfully using the Code generated by CubeMX
SKris.1616
There is same post available in the community but there is no solution available yet. When we generate code with 1bit wide SD card interface then we are able to successfully mount the card. Same thing with 4 bit we are not able to.
If anyone have solution please share it.
Suresh.
Yes, seems like a recurrent problem for CubeMX users. You might want to cross-link threads.
There is usually serviceable code within the HAL examples for the specific "STM32" being used.
dbgarasiya
Senior II
you have another isssue , i have done succesfully mounted sd card with 4 bit
what your issue?
debug through f_mount .
dbgarasiya
Senior II
find problem?
