STM32CubeMX (MCUs)
Ask questions on STM32CubeMX. Discuss code generation and configuration challenges, among other topics.
STM32CubeMX 6.17.0 released
We are pleased to announce that version 6.17.0 of STM32CubeMX is available. What is new in 6.17.0: Added support for new microcontrollers across the STM32WBA, STM32H5, and STM32U3 seriesAdded support for new boards: NUCLEO-WBA25CE1, NUCLEO-H5E5ZJ, ST...
Aimen1 by ST Employee
  • 1568 Views
  • 0 replies
  • 2 kudos
Is it possible to change peripheral instance name?
Hi, I'm developing some firmware having in mind a possible future need for portability. Being so, I thought about labeling pinouts on the Device Configuration Tool (DCT) and generate code (in the future, giving the same pin names to different pin gro...
PMach.3 by Associate II
  • 1799 Views
  • 1 replies
Hi! I am trying to install the STM32CubeMX 6.8.0 on my macOS 13.3 (Ventura),when I run the installer it gives me the following error: You cannot open the application SetupSTM32CubeMX-6.8.0.app because it is corrupted or incomplete.
I have installed Xcode and tried to run the instructions "In case of error, try one of the following fixes: - $sudo xattr -cr ~/SetupSTM32CubeMX-6.8.0.app."
CColo.2 by Associate III
  • 2752 Views
Resolved! Don't see DAC output for SINE wave with DMA
Hello,I followed a tutorial on how to generate a SINE wave using DAC and DMA that was really good. Logically it makes sense, you set up the DAC, set it to be triggered by a timer, then set up the DMA channel, set it to circular, and set it to use a t...
0693W00000FAgEAQA1.png 0693W00000FAgE5QAL.png 0693W00000FAgEFQA1.png 0693W00000FAgEeQAL.png
