STM32CubeMX (MCUs)
Ask questions on STM32CubeMX. Discuss code generation and configuration challenges, among other topics.
STM32CubeMX 6.17.0 released
We are pleased to announce that version 6.17.0 of STM32CubeMX is available. What is new in 6.17.0: Added support for new microcontrollers across the STM32WBA, STM32H5, and STM32U3 seriesAdded support for new boards: NUCLEO-WBA25CE1, NUCLEO-H5E5ZJ, ST...
Aimen1 by ST Employee
  • 1568 Views
  • 0 replies
  • 2 kudos
Resolved! STM32CubeMX display resolution problem
Posted on June 27, 2017 at 16:27Hello ST team,I think the STM32CubeMX code generator has a big problem with screen resolution. I'm using a laptop with 4K display, so my CubeMX appears like following screenshots, which are annoying in many cases: Alm...
misagh by Associate III
  • 6036 Views
  • 13 replies
  • 1 kudos
I found a Bug about the NAND Flash Driver of STM32F7
Posted on October 24, 2017 at 06:21When I meet a bad block in a NAND flash,it will stop here forever.The 'tickstart = HAL_GetTick()' should put in front of 'while(HAL_NAND_Read_Status(hnand) != NAND_READY)'.#nand-flash-driver #stm32cubemx #bug
stm32cubeMX doesn't modify/generate the system_stm32l0xx.c
Posted on October 17, 2017 at 12:49Hi All,in order to build new project (using STM32l073v8t processor) folder, I used the STM32cubeMX.I've set all IOs, change the clock tree using its UI and etc' according to my project.When I check the generated co...
moranf by Associate II
  • 1893 Views
  • 3 replies
STM32CubeMX LL Driver Issues
Posted on July 25, 2017 at 11:08I found two issues with the latest (and updated) STM32CubeMX when generating a Makefile project for STM32F334 Nucleo64 board.1. I selected only the LL drivers but the Makefile had the 'USE_HAL_DRIVER' definition, so t...
Resolved! STM32L452CEU6 HSI Problem
Posted on June 03, 2017 at 20:12I have a board which was designed to use the STM32L433CCU6 and am attempting to use it with an STM32L452CEU6.  The board works perfectly fine with the 433, but I am struggling a bit with the 452.  The problem I was fa...
NUCLEO-F746ZG With MQTT Using CubeMX
Posted on March 21, 2017 at 10:16Hi I have a NUCLEO F746ZG board. How I initialize ethernet using CubeMX and using MQTT Protocol to transfer my data to MQTT broker ?#ethernet #f746zg #mqtt #nucleo #cubemx
stm32f446re microSD SDIO
Posted on October 05, 2017 at 08:56Hi all,I am using the latest stm32cubemx with a stm32f446re Nucleo board and I am trying to access a microSD card. I have soldered headers to a microSD to SD adaptor and connect all the pins to the corresponding pi...
giolenas by Associate II
  • 6965 Views
  • 9 replies
