STM32CubeMX (MCUs)
Ask questions on STM32CubeMX. Discuss code generation and configuration challenges, among other topics.
STM32CubeMX 6.17.0 released
We are pleased to announce that version 6.17.0 of STM32CubeMX is available. What is new in 6.17.0: Added support for new microcontrollers across the STM32WBA, STM32H5, and STM32U3 seriesAdded support for new boards: NUCLEO-WBA25CE1, NUCLEO-H5E5ZJ, ST...
Aimen1 by ST Employee
  • 1575 Views
  • 0 replies
  • 2 kudos
why do I get this error during the build process?
I get the following error. Unfortunately, I can not fix that. The call to stm32_make_rtw_hook during the entry hooks generated the following error: The DefaultParameterBehavior property does not exist The build process will be terminated. to the soft...
Samuel1 by Associate III
  • 1337 Views
  • 1 replies
problems with STM32H7_HAL and SDHC 32Gb
i want to open a file in a SD_Card (mode SD 4 bits wide bus) fres=f_open(&fil, "fit5.txt", FA_OPEN_ALWAYS | FA_WRITE);but:1- the program work fine with SanDisk uSD 2GB. -> f_res=FR_OK2- the program not work with Kingston uSDHC (gen 10) 32 GB. -> f_re...
dresc by Associate II
  • 2942 Views
  • 9 replies
how do i interface SDRAM with STM32F446VET controller
I read about FMC(Flexible memory controller) to interface memory,but while selecting memory type in cubemx it shows only Muxed PSRAM,Muxed NOR FLASH.i haven't find any SDRAM option .which type of memory i need to select?can i interface SDRAM if i ...
Predd.11 by Associate II
  • 954 Views
  • 1 replies
