STM32CubeMX (MCUs)
Ask questions on STM32CubeMX. Discuss code generation and configuration challenges, among other topics.
STM32CubeMX 6.17.0 released
We are pleased to announce that version 6.17.0 of STM32CubeMX is available. What is new in 6.17.0: Added support for new microcontrollers across the STM32WBA, STM32H5, and STM32U3 seriesAdded support for new boards: NUCLEO-WBA25CE1, NUCLEO-H5E5ZJ, ST...
Aimen1 by ST Employee
  • 1560 Views
  • 0 replies
  • 2 kudos
SDCard SDIO 4Bit with DMA using FatFs Q1: How to check if DMA is working? Q1: How to check if 4Bit Mode is set correctly?
Hi Community, I use a STM32F405 to access a uSDCard.Software: CubeMX V5.3 and SW4STM32 (Eclipse Neon.3 Release (4.6.3))The good news, I can communicate with the SDCard (create files, write content and delete files. So far so good, but now the questio...
AWilk by Associate
  • 3178 Views
  • 4 replies
  • 2 kudos
I am using STM32F407 development board and I am trying to do flash read write operation but I am facing problem to erase a sector but am not able to do that.
Hi All,I am using STM32F407 development board and I am trying to do flash write operation but I am facing problem to erase a sector (I am using Sector no - 11 Block base addresses -0x080E 0000 - 0x080F FFFF size-128 Kbytes ) so that I can perform mul...
Djain.1 by Associate II
  • 2186 Views
  • 3 replies
Feature request : evalboard view
Hello, Currently cubeMx provides a pinout view usefull to see what is in use and to choose alternatesdepending of board layout constraints.Would it be possible to add an "eval board" view which would allow to see basically the same information but on...
JulienD by Senior
  • 1531 Views
  • 3 replies
  • 2 kudos
How to power off D1 or D2 domain using CubeMX?
Board: Nucleo - H745ZI-QSw: Cube MX 5.6.0I want to use cube mx for generating simple blinky code (I use the board specific details), for some reason it doesn't work out, I suspect its because I cant specify how both cores will work together from MX. ...
sarojj7 by Associate III
  • 1322 Views
  • 1 replies
