STM32CubeMX (MCUs)
Ask questions on STM32CubeMX. Discuss code generation and configuration challenges, among other topics.
STM32CubeMX 6.17.0 released
We are pleased to announce that version 6.17.0 of STM32CubeMX is available. What is new in 6.17.0: Added support for new microcontrollers across the STM32WBA, STM32H5, and STM32U3 seriesAdded support for new boards: NUCLEO-WBA25CE1, NUCLEO-H5E5ZJ, ST...
Aimen1 by ST Employee
  • 1549 Views
  • 0 replies
  • 2 kudos
Resolved! Should these be these?
I found these prompt in my "main.c" of NonSecure generated by MX for NUCLEO L552ZE-Q: /* USER CODE BEGIN WHILE */ while (1) { /* USER CODE END WHILE */   /* USER CODE BEGIN 3 */ } /* USER CODE END 3 */ }should it be this? /* USER CO...
MQi.1 by Senior II
  • 1564 Views
  • 4 replies
Resolved! Where are the smps LDO settings in the configuration tool?
Configuration tool auto generated code SystemClock_Config() calls HAL_PWREx_ConfigSupply(PWR_DIRECT_SMPS_SUPPLY). For my hardware i need to use PWR_SMPS_1V8_SUPPLIES_LDO with no voltage scaling. I cannot find where to change the power supply config...
TFran.4 by Associate II
  • 1522 Views
STM32H745iit Difference between CUMBEMX and datasheet pin 48
There is a difference between CubeMx and the datasheet. from Pin48https://community.st.com/s/?t=1610970558389Datasheet - STM32H753xI - 32-bit Arm® Cortex®-M7 400MHz MCUs, up to 2MB Flash, 1MB RAM, 46 com. and analog interfaces, crypto page 56/252Data...
Hans T by Senior
  • 878 Views
  • 1 replies
Resolved! STM32CubeMX latest version Bug?
Hello,I have just updated to the latest: STMECubeMX to version 6.1.1. and STM32CubeF1 Firmware Package V1.8.3 / 20-October-2020. Part Number: Stm32f103RCTx. And I have found the bug - probably ? When you use SDIO and define it as 1bit, the CubeMX...
RnnKrk by Associate II
  • 1679 Views
Unable to install ANY packs on STM32CubeIDE
So, I'm trying to get my project started in anticipation of the arrival of my STM32L562-DK board, and having unusual difficulty.I asked another question about code generation, so will not reiterate here. I upgraded to 1.5.1, and now I'm in a very odd...
KHenr.1 by Associate
  • 883 Views
  • 0 replies
Resolved! Project>Build Project greyed out/nonfunctional
Why does this happen ? Could this, in part, be due to me not knowing whether to choose "new C project" vs "new C++" project?Using: STM32CubeIDE 1.5.1Build: 9029_20201210_1234 (UTC)OS: Windows 8.1, v.6.3, x86_64 / win32Java version: 1.8.0_272
RPasc.2 by Associate III
  • 1888 Views
  • 1 replies
