TTeag.1
CubeMX IDE v1.3.1, MacOS 10.14.6, Build fails with "/bin/sh: arm-none-eabi-objcopy.exe: command not found" - the ".exe" is incorrect.
  • June 23, 2020
  • 3 replies
  • 1342 views
The makefile is not correct with: arm-none-eabi-objcopy.exe -O ihex "IOproc.elf" "IOproc.hex", but the IDE is trying to run arm-none-eabi-objcopy.exe.
I just reinstalled the IDE using the Mac installer - no change. How can I get the IDE to generate a makefile that does not have ".exe"?
Not real sure why it's appending the .EXE. It doesn't do this on Windows 10.
You can always add the ELF to HEX conversion as a postprocessing step in project properties -> C/C++ Build -> Settings -> Build steps -> Post-build steps
TTeag.1
TTeag.1Author
Perfect! On the Mac, that step is incorrectly specified. Simply removing the ".exe" in the location mentioned above solved the problem.
Thank you very much.
Interesting. On my machine, ELF -> HEX generation is done by a checkbox on a different screen. I assumed you were doing the same. Maybe your project file was created for windows and someone added that as a post build step. In any case, glad you got it sorted out.
